notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Aug 24, 2005 11:02 am Post subject: |
I have never seen one. I don't see the problem with the stock shifter. If they are adjusted right, and the coupling is good, you can shift them as well if not better than anything else.
Now, if you are an accessory whore, that is a different story. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Wed Aug 24, 2005 11:11 am Post subject: |
Russ Wolfe wrote: |
if you are an accessory whore, that is a different story. |
don't know that I have ever been called that before... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Aug 24, 2005 11:46 am Post subject: |
I'm with Russ on the shifter thing. VW transmissions are durable, but exceedingly prone to wear if the shifter weight or dynamics are altered much. If you have an owner's manual for your car, it'll tell you not to rest your hand on the shifter while driving, or you'll wear the trans! For that reason, I've ALWAYS been leery of any sort of aftermarket or accessory shifter. That thing doesn't look like a factory or dealer accessory.
Plus, it's fugly! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Wed Aug 24, 2005 5:14 pm Post subject: |
There's nothing wrong with that design. Not pretty, that's for sure! I prefer the after-market shifters because I'd rather pull a trigger or push a button than push down. Hmm...I should design something like that for my Mk.III VW shifter cuz that's gotta be pushed down as well to go to reverse (but you shift up instead of down). _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
