ladybug Samba Member
Joined: March 15, 2004 Posts: 149 Location: Sacramento, Ca
Posted: Sat Feb 05, 2005 10:08 am Post subject: Media blasting |
I have been removing the paint off my bug with a chemical stripper. I have little parts ( front hood springs, tail light housings, etc.) that I need to remove the paint from, too. I'm thinking just to blast them with some sort of media, instead of a chemical strip. My question is, after it gets painted, can you tell the difference between a chemical strip and media blasting? I want them to look the same after its done. Also, what is the best media to use? _________________ '72 Superbeetle, 1776, Kadron carbs, headers, hide-a-way muffler, front end lowered 2", 195/50/15 in front, front disc brakes and soon to be painted. |
orangerail Samba Member
Joined: October 01, 2004 Posts: 266 Location: salisbury,nc
Posted: Sat Feb 05, 2005 6:57 pm Post subject: blasting |
blasting is much better if you have the equipment,chemical stripping works also , don't get me wrong but you have to put the chemical on then wait , clean off, sand then paint.......blast it.....you blast it , prime then paint....alot less work in my book......just bought a blaster yesterday as a matter of fact....got tired of going to a friends house to do my stuff.....i use a glass media in the blaster works good for me.....some like others thats what i use.....you can get a fairly inexpensive blaster at northern tool and equipment....like i said got one last nite and it works great(as long as you have a compressor) _________________ don't worry what other people think,do what you want to,and let them learn from you!!!! |
groovinvwdriver Samba Member
Joined: February 01, 2005 Posts: 2 Location: Philadelphia, PA
Posted: Sun Feb 06, 2005 10:33 am Post subject: more info' on your new blaster please |
how much and where did you buy your blaster?
_rob _________________ "stay positive"
1974 Volkswagen Beetle - Brilliant Orange - 1600cc
2005 Volkswagen Beetle - Reflex Silver - 1.9 TDI PD
1998 Jeep Wrangler - Patriot Blue - 4.0L |
Posted: Sun Feb 06, 2005 6:28 pm Post subject: blaster |
got mine from northern tool and equipment(formerly northern hydralics) for $149.....its a bech top model....plastic cabinet.....for as much as i do it will work fine _________________ don't worry what other people think,do what you want to,and let them learn from you!!!! |
bmtx Samba Member
Joined: December 28, 2004 Posts: 606 Location: The Lone Star State
Posted: Wed Feb 09, 2005 10:01 pm Post subject: |
It would be kinda hard to get a door in that benchtop, would'nt it |
multiplex Samba Member
Posted: Thu Feb 10, 2005 10:47 am Post subject: |
you can get a blaster from harbor freight.. i did my whole bug that way..
blasting is much better, but you need to be careful not to distort the metal.. always hold the gun at atleast a 45 degree angle to the panel..
i usually strip with chemicals first, and then clean up with the blaster.. (less stress on the metal)
blasting creates a rough finish which is great for primer bonding..
checmical stripping can be more difficult becuase you need to make sure the metal is clean of all residue before you paint, or you will end up with a mess. |
bmtx Samba Member
Posted: Thu Feb 10, 2005 2:57 pm Post subject: |
The chemical also winds up being more work if you have a car with a lot of body filler. After the chemical does its thang you still have to sand alot as where a media blast takes it all off. |
