Rear wheel noise
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
beckster
beckster is offline
PostPosted: Thu Feb 10, 2005 4:13 pm    Post subject: Rear wheel noise Reply with quote
Is this my only problem?.
I had a noise in the rear wheel every time I put on the brake. There was some pulse in the brake . I replaced the brake drum and put silicone spray on the back of the backing plate where it meets the bearing box and the noise is gone. Is this a common problem with the Vanagon or is it future bearing and stub axle replacement. There is no noise at higher speeds.
Thanks
mjamgb
mjamgb is offline
PostPosted: Thu Feb 10, 2005 9:54 pm    Post subject: Reply with quote
I have a pulse in the brakes too but I'm nearly ceratin the shop that turned the drums got them an itty bitty bit off-center (or one at least).
No trouble at speed either.
I DID just replace one rear wheel bearing but the howl was obvious and it got worse in a hurry (within 100 miles). Typical.
If your pulsing went away then I'd be pretty happy, myself Very Happy !
Mike!
earthmuffin
Samba Worm Farmer
earthmuffin is offline
PostPosted: Thu Feb 10, 2005 9:58 pm    Post subject: Reply with quote
All cars can have problems with warped drums or rotors. If you replaced the drum and its gone, you probably got it.
If your wheel bearing was on its way out, the noise would be constant and would not go away when the brake is applied.
This thread SUCKS!!!
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
