74 Cosa Samba Member
Joined: June 06, 2006 Posts: 535 Location: The Midwest
Posted: Tue Jan 31, 2012 8:55 pm Post subject: |
Does this help? |
bcampagnolo Samba Member
Joined: August 29, 2011 Posts: 165 Location: United States
Posted: Tue Jan 31, 2012 11:30 pm Post subject: |
Thanks for the reply.
What about that hole in the bottom by the light? Is that just a hole or should I hang the little tree air freshener from there? _________________ Paul
67 Walkthrough 13 Window |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Wed Feb 01, 2012 7:48 am Post subject: |
bcampagnolo wrote: |
...What about that hole in the bottom by the light?... |
Good question. I've seen different style camper curtain rods attached there. I hang my cross-the-cab curtain holder there in one of my busses. Maybe someone with a cab divider will say that it's functional. Don't get the dome light wire stuck under the spring strip. |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Thu Nov 29, 2012 5:48 pm Post subject: |
Iam about to do my overhead vent seals and found this thread. From the looks of 74 Cosas last above photo the side vent flaps move all the way to the side and cover the side grills?? Mine have about an inch or two of space when turned to the side positon, somebody has been in there before and I hope just put it back together wrong. Are the flaps supposed to make contact with the inside of the grill to stop the air flow? Thanks to all of you guys that posted the pictures and write ups, very helpful. |
BarryL Samba Member
Posted: Thu Nov 29, 2012 7:50 pm Post subject: |
Yes they are supposed to slap up against the louvers to seal and direct the air rearward. Probably the rubber seal is falling down and apart causing that gap: common. |
Posted: Thu Nov 29, 2012 9:31 pm Post subject: |
Thanks BarryL |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
grey60 Samba Member
Posted: Fri Dec 06, 2013 10:57 am Post subject: |
Meanwhile, in the same vicinity of the bus …
My plunger doesn't plunge. Note broken end opposite the c-clip.
Anyone have a pic or know measurements of the original piece or how to hack a DIY replacement?
Thanks _________________ 1960 grey panel |
BarryL Samba Member
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Sat Dec 07, 2013 2:16 am Post subject: |
No, Barry, that looks like an A71.
http://oacdp.org/5867part/383.png _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
BarryL Samba Member
Posted: Sat Dec 07, 2013 9:17 am Post subject: |
Oh, yeah, cha bro. So right.
I fell for the "12mm" part of it thinking that's how long it was. Sheesh. A71 doesn't tell you diddly about length. |
grey60 Samba Member
Posted: Sat Dec 07, 2013 7:10 pm Post subject: |
A72, the spring, is 32 mm long and about 6 mm ID.
The remains of A71 that I have are 32 mm x 5 mm, round, black plastic …
I can reproduce something that works for me, but I need to see what an original piece looks like unbroken. _________________ 1960 grey panel |
BarryL Samba Member
Posted: Sun Dec 08, 2013 8:53 am Post subject: |
All I can give you. I think mine is steel.
grey60 Samba Member
Posted: Mon Dec 09, 2013 10:11 am Post subject: |
BarryL wrote: |
That will do nicely. Thanks!
I can extrapolate from this and figure out something that will work. _________________ 1960 grey panel |
Stocknazi Samba Member
Posted: Mon Dec 09, 2013 7:35 pm Post subject: |
it's plastic
i have an extra somewhere if i can find it _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
John TC Samba Member
Joined: August 14, 2010 Posts: 117 Location: Jersey UK
Posted: Wed Dec 11, 2013 2:30 pm Post subject: |
not able to find the correct grommets, I cut short sections of rubber pipe as a substitute
flap setup
grey60 Samba Member
Posted: Wed Jan 01, 2014 11:26 am Post subject: |
grey60 wrote: |
BarryL wrote: |
I can extrapolate from this and figure out something that will work. |
And now I present for your amusement -- one over-engineered vent flap pin thingy:
Cobbled together from sundry hardware left over from an RC crawler project.
I might replace the stainless ball joint piece with a plastic equivalent if it's too hard on the opposing metal surface… or my ears. _________________ 1960 grey panel |
DadaCheese Samba Member
Joined: April 15, 2008 Posts: 835 Location: Richmond, CA
Posted: Tue Oct 07, 2014 7:01 am Post subject: Start of replacing/restoring overhead air vent seals |
This thread is excellent and took some of the mystery out of the few words that the Bentley manual had to say on the subject.
I've started this project, and will post a variety of (hopefully) helpful pictures and words on the experience when I am done. That'll be awhile, but before Thanksgiving...
Inexperienced question:
To get some of the old directional flap cleaned up, and the old flap material off, I have steel-wooled and sanded down to bare metal in part.
Should I/do I need to spray paint these parts?
What about the ones that have rust (like the flap part); how "clean" should I be getting these?
Lastly; the right adjustment screw which holds the flap to the controller rod broke. Easy to find part at a hardware store? Suggestions?
Thanks!
_________________ ----------------------------------------------------------
Dada as in dadaism.
Cheese as in the stuff I love to eat. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Tue Oct 07, 2014 7:37 am Post subject: |
Definitely would remove rust and paint.
You could have your local powder coat shop sand blast the pieces, spray on a marine zinc primer and color coat in black or what ever suits your fancy.
Or do it yourself at home with phosphoric acid till clean of rust, rinse and dry, high content zinc primer and use a good quality spray paint.
Screw should be an easy hardware store or fastener supply shop. Next time, do not just go for broke like that. Instead try wiggling the screw tighten/loosen a tiny amount back and forth to get it to move. Before just trying to turn it all the way loose. _________________ In Stereo, Where Available! |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Sep 12, 2016 1:30 pm Post subject: Re: Overhead air vent in cab roof - seals and functionality |
The piano wire hinge on one of my flaps is busted. Anyone ever have any luck banging the old one out and new wire in? Any idea on the size?
_________________ 1957 Beetle
1966 Bus |
