Failed Big End???
mercutio
mercutio is offline
PostPosted: Sun Feb 27, 2005 11:57 am    Post subject: Failed Big End??? Reply with quote
Hi,
Do the following symptoms sound like a failed/weak rod bearing:
- Consistent "knocking" sound at idle, less when cold.
- Knocking diminishes as engine rev's up
- Knocking is louder and settles to original level when throttling off.
Any other possibilities or tests???
Thanks in advance.
M
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Feb 27, 2005 11:59 am    Post subject: Reply with quote
Hate to say it, but that is what it sounds like. That of a cracked crankshaft.
Loose flywheel will make the same sounds all the time, hot or cold.
Gary: OK. Ima poop.
familyof3type3
familyof3type3 is offline
PostPosted: Tue Mar 01, 2005 11:40 pm    Post subject: Reply with quote
had same issue ended up being that the fan was off a bit and was hitting the aluminum shroud. Not sure why it made more noise at operating temp but it was less noticeable when cold.
lookin for a nice early 60's type 3
FASTBACKDON
The other insensitive jerk like Neil
FASTBACKDON is offline
PostPosted: Fri Mar 04, 2005 12:37 pm    Post subject: Reply with quote
my old motor did the same thing turned out to be a loose fan housing
chubby53
chubby53 is offline
PostPosted: Tue Mar 08, 2005 10:11 pm    Post subject: Reply with quote
I had an engine with a knock so bad I thought it was going to throw a rod on the way home. Started to pull apart the engine and the fan was loose and I could rotate it a quarter inch opposite the crank. I replaced the fan and all was well.
