hiperman70 Samba Member
Posted: Tue Mar 01, 2005 11:58 pm Post subject: where to start? |
hello,i just bought a 1972 fastback?
this is my first car project,what is the first thing i should do?besides pray
should i take all the body parts off,then take the shell of the frame?the body looks good,but cant really tell it has two coat of paint on it.i do want to repaint the car myself.I just got my garage set up and iam ready to go,but want to start things off right .i do have all of the inside of the car taken out.can anyone tell me were i should start and the steps i should take.thanks |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Wed Mar 02, 2005 9:32 am Post subject: |
what are you after?...how much time and money are you willing to put into it?...you need to assess how much bad crusty rust you have in structural parts and wether you plan to fix them or not...simple surface rust is no big deal...if you need to replace metal, plan on a long, time consuming, expensive project...start by cleaning up the areas that need metal replacement and assess your situation...
if you can get away without replacing metal and just want to freshen up the paint, then you have a couple options to consider:
if you have more money than time, consider media blasting...make sure you find a good blaster, because vw sheet metal warps easily...this will take it down to bare metal quickly...
if you have lots of time and no money, consider sanding it down with DA sander, and sanding blocks/sand paper...you want to get it down to original paint/primer...you only absolutely need to expose metal where there is surface rust and bubbleing OG paint
this will get you started thinking...use the search button...lots of this stuff has been discussed to death on the threads and good luck with the project...it's a lot of work...but rewarding and educational.... _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
