karfer67 Samba Member
Posted: Thu Mar 03, 2005 10:35 pm Post subject: do all late squarebacks hafe trip speedos? |
mine does although it does not work and i am looking to have it rebuilt. is this rare or is this how they all are? _________________ aircooled for life (1972 squareback cal look) |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Thu Mar 03, 2005 11:37 pm Post subject: |
Both my '72s have them and they work. I know my baby is still the original working unit...250,000+ miles!
Try taking it to a speedometer repair shop. _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Anniehum Samba Member
Joined: November 23, 2003 Posts: 1197 Location: Kingston, Washington
Posted: Thu Mar 03, 2005 11:57 pm Post subject: |
neither of my 70' squares does. Would make it easier to figure milage but that is what a pen and pad are for.
Cheers _________________ Ho'oponopono |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Fri Mar 04, 2005 12:08 am Post subject: |
IIRC, the trop odometer started as a standard feature in '71 .. I *think* it was an option before that, but I could just be blowing smoke out of my ass. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Fri Mar 04, 2005 9:29 am Post subject: |
I think it was standard for the USA after some point. Maybe '71 as mentioned.
The earliest I have seen it in that I believe was correct was a '69 Fastback I just sold. It was bought from the original owner and was sort of low mileage so I think it was original.
I did not remove it to check the date. _________________ How to Post Photos
Posted: Fri Mar 04, 2005 9:43 am Post subject: |
i thought they were standard on the late ones. well my next question is does anyone have a late speedo that works that they want to sell? the odometer in mine does not work. _________________ aircooled for life (1972 squareback cal look) |
Phatusatus Samba Member
Joined: May 29, 2004 Posts: 99 Location: Chandler, AZ
Posted: Fri Mar 04, 2005 11:29 am Post subject: |
The speedo and odometer/trip did not work when I got my car. When I did the brakes, I found a broken speedo cable. I replaced the cable, but it still did not work. I took apart the speedo and found that the grease had became hardren (age/dirty) and was not allowing the the gears to turn. I also found that a gear ( for the reset function) for the trip had sled out a little. I cleaned, reset the gear, and relube...works great now.
FYI...the display needle breaks easily...don't ask how I know. _________________ Click to view image |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Sat Mar 05, 2005 5:54 pm Post subject: |
EverettB wrote: |
I think it was standard for the USA after some point. Maybe '71 as mentioned. |
My 71 didn't come with a trip, and my dad's 71 that he had didn't come with a trip, so it must be a 72 thing. My 71 has the correct date coded speedo with the 10ths in it, and my wife's 70 still has it's OE speedo in it too. That being said, I had Jim Adney rebuilt the early 72 unit that I've got in my 65 Notch. It works great too, so if you need one done, I'd contact him. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Mar 05, 2005 6:28 pm Post subject: |
Bobnotch wrote: |
EverettB wrote: |
My 71 didn't come with a trip, and my dad's 71 that he had didn't come with a trip, so it must be a 72 thing. My 71 has the correct date coded speedo with the 10ths in it, and my wife's 70 still has it's OE speedo in it too. That being said, I had Jim Adney rebuilt the early 72 unit that I've got in my 65 Notch. It works great too, so if you need one done, I'd contact him. |
Ok. I have seen A LOT of CA '71s with trip speedos. Maybe we need them more here _________________ How to Post Photos
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Mar 05, 2005 6:34 pm Post subject: |
My '71 FB had a trip Odometer from the factory. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sat Mar 05, 2005 8:29 pm Post subject: |
i love having a type 3 and talking to you guys. no one has slammed me for my mispelling of have lol. anyways what is that guy's name here on samba so i can contact him? other wise i am having to guess how many miles to go between oil changes and valve adjustments so obviously being a little over the top i will be doing them closer together than they probably need to be not that is really a bad thing. hey bob if you see this i got into an argument over the use of full flow filter pumps and whether or not they were good. the real argument started when i mentioned that you change your oil more often and you have a lot of miles on your engines. i feel this is a safe way to go on a mild or stock engine. just thought i would pass this along. _________________ aircooled for life (1972 squareback cal look) |
Posted: Sat Mar 05, 2005 10:07 pm Post subject: |
thanks again bob for all your help. hey that type 3 in your avatar is that yours? _________________ aircooled for life (1972 squareback cal look) |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Sat Mar 05, 2005 11:04 pm Post subject: |
hey last time I looked there was one in a squareback at the area 51 yard by mather field. I was going to pull it but there was a kid and his baby pulling something out of a bug and the kid was screaming, I decided it wasnt worth it to me. It looked nice though, as did the car _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Sun Mar 06, 2005 1:27 pm Post subject: |
karfer67 wrote: |
hey that type 3 in your avatar is that yours? |
No, but it's similar. Mine's a "late" model, has the rear cargo area closed in, and it's currently flat black with white scallops. Pics have been posted in the forums and in the gallery in the Squareback section, or even the link in my signature. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Mon Mar 07, 2005 9:02 pm Post subject: |
'72 Square - bone stock
no trip odometer in the speedo...
what gives? _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Mon Mar 07, 2005 10:00 pm Post subject: |
wow bob that is very nice looking. makes fopr an interesting design. wonder what vw would have called that one. lets see we have the squareback, notchback, fastback what would they call it bareback? lol maybe thats why they never made one. sweet type 3 u got there. _________________ aircooled for life (1972 squareback cal look) |
wynsquezr Samba Member
Joined: March 08, 2005 Posts: 163 Location: 38d N 121d W
Posted: Tue Mar 08, 2005 11:07 am Post subject: |
My 71SB has the trip meter but doesn,t work now but I saw another post about old grease,etc needing to be cleaned out and will have to try |
fastfred Samba Member
Posted: Wed Mar 09, 2005 6:29 am Post subject: trip... |
i have several trip-speedos... about four i think.
i think three of them are 1973.
i might sell two of them (they are working)
any takers ?
cya
ffred
[email protected] |
Posted: Wed Mar 09, 2005 6:39 am Post subject: Re: trip... |
fastfred wrote: |
any takers ?
cya
ffred
[email protected] |
thanks, but I have two working ones in a box... plus a full array of other gauges... _________________ póg mo thóin
