josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
67FastyRSA Samba Member
Joined: September 28, 2004 Posts: 179 Location: Presov, Slovak Republic
Posted: Sat Mar 05, 2005 1:35 am Post subject: |
would be nice to have the dimentions of a 411/412 boot although i think that they might be hell to try and find..... Just a word of warning.... if you are going to try and clamp the type 3 boot on the flange as it is, it WILL tear. The original type 3 boots are made from natural rubber which is very brittle. I think it would be better to try and modify the boot on the flange side and use rubber cement to seal it where you modified it. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sat Mar 05, 2005 5:30 am Post subject: |
just thinking out loud, so bear with me:
can you cut the cooling flange off the Type 3 tin and weld it on the Type 4 tin, giving you the correct shape for both the rubber boot and the cooling duct on the Type 3 body?
again, just suggesting... but couldn't this be done? _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
BryanM Samba Member
Joined: June 14, 2002 Posts: 4212 Location: Concord/Charlotte NC
Posted: Sat Mar 05, 2005 7:42 am Post subject: |
blankmange wrote: |
again, just suggesting... but couldn't this be done? |
I have a intake tin that someone did that to. _________________ -Bryan
Motorwagen LLC
Concord NC |
Posted: Sat Mar 05, 2005 8:18 am Post subject: |
BryanM wrote: |
blankmange wrote: |
I have a intake tin that someone did that to. |
and - how did it turn out? _________________ póg mo thóin
BryanM Samba Member
Posted: Sat Mar 05, 2005 8:34 am Post subject: |
blankmange wrote: |
BryanM wrote: |
blankmange wrote: |
and - how did it turn out? |
I havent bolted it up yet but it looks pretty good, I'll have to get pics _________________ -Bryan
Motorwagen LLC
Concord NC |
Posted: Sat Mar 05, 2005 8:41 am Post subject: |
BryanM wrote: |
blankmange wrote: |
BryanM wrote: |
blankmange wrote: |
I havent bolted it up yet but it looks pretty good, I'll have to get pics |
yeah - pics would be good; I have the parts to do this when I get to the Type 4 conversion, so was interested in how it all works out... _________________ póg mo thóin
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Sat Mar 05, 2005 10:50 am Post subject: |
blankmange wrote: |
can you cut the cooling flange off the Type 3 tin and weld it on the Type 4 tin, giving you the correct shape for both the rubber boot and the cooling duct on the Type 3 body? |
Problem is, that Type 4 piece that Josh posted pics of isn't tin. It's plastic. I'd *love* to find someone who can weld metal to plastic.
Seriously, though, if I can ever get myself motivated again .. I was working on something like that, but in fiberglass. Didn't get too far before I had to pack everything up to move and haven't had the ambition to get back into it yet.. |
Posted: Sat Mar 05, 2005 11:06 am Post subject: |
tristessa wrote: |
blankmange wrote: |
I see what you are saying; the fan assembly on the Type 4 motor sitting on my bench is metal, so welding the T3 flange onto it shouldn't be that tricky, other than cutting it to size... _________________ póg mo thóin
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Sat Mar 05, 2005 11:13 am Post subject: Re: Type4 conversion flange |
Until I saw the LAST image I had no reference as to what I was looking at.
I think a fiberglass conversion part would be a good idea. _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Sat Mar 05, 2005 5:29 pm Post subject: |
blankmange wrote: |
I see what you are saying; the fan assembly on the Type 4 motor sitting on my bench is metal, so welding the T3 flange onto it shouldn't be that tricky, other than cutting it to size... |
Ah, welding steel to aluminum .. that's also a neat trick I'd like to see. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Mar 05, 2005 6:19 pm Post subject: |
tristessa wrote: |
blankmange wrote: |
Welding steel to Magnesium, That a trick I would like to see only on the 4th of July.
That fan housing is magnesium. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sat Mar 05, 2005 7:07 pm Post subject: |
Russ Wolfe wrote: |
Welding steel to Magnesium, That a trick I would like to see only on the 4th of July.That fan housing is magnesium. |
Oooh! Even better! I was *guessing* that it's aluminum since that's what the T4 case is made of.. |
Posted: Sat Mar 05, 2005 8:09 pm Post subject: |
tristessa wrote: |
Russ Wolfe wrote: |
sounds like a job for JB Weld!!! _________________ póg mo thóin
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Sat Mar 05, 2005 8:19 pm Post subject: |
The type 4 fan housing is aluminum. _________________ OGST
Samba Member #4862 |
Posted: Sat Mar 05, 2005 8:59 pm Post subject: |
Mr. Bubblehead wrote: |
The type 4 fan housing is aluminum. |
Are you sure??
I was told at VW schools that they were magnesium.
I know T-3's are magnesium. We use them for pyrotechnics on the 4th.
It does take a torche to get them started. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Sun Mar 06, 2005 12:27 am Post subject: |
this reminds me of the Space Race.... Fountain pens didn't work so well in space so the Americans had the ball-point pen invented...
meanwhile the Russians just used pencils...
... seriously... using the plastic flange and just adapting the boot a little bit is less trouble and works well... |
Posted: Sun Mar 06, 2005 4:14 am Post subject: |
Just touching on another stumbleblock you might encounter.... oil filler
Have any of you guys seen if a type 3 filler tube would bolt on correctly to the type iv case? I would love to not to have to open the lid to check oil ....(and top up of course) |
josh Samba Member
Posted: Sun Mar 06, 2005 5:21 am Post subject: |
Quote: |
Have any of you guys seen if a type 3 filler tube would bolt on correctly to the type iv case? |
I'm also curious about this. I've looked into this a little. While their different getting the type3 filler to fit the case is no big deal. I havent really checked into fan housing clearance though. Another worry after comparing the type 3&4 cases is wether or not enough oil would flow into the tube to get a good reading. Trying to get the bus dipstick to line up with the type3 body is another option.
Another issue: I'm using a 914 case. Do i cut a hole in the case to add a filler and dipstick? |
