hiperman70 Samba Member
Posted: Sun Mar 06, 2005 9:33 pm Post subject: help,removal of windows |
hello,i need help on removing the 2 sides ,and rear window?is there anyway that i can save the rubber,this is a 71 fasty the sides aren't pop outs. thanks |
Naked Samba Member
Joined: August 03, 2004 Posts: 568 Location: Lincoln, Ca
Posted: Mon Mar 07, 2005 12:41 am Post subject: |
I would think if you pulled out the lock stripe (I think it has that for the chrome moulding) then get a buddy on the outside of the window, you get inside and push it out with your feet real slow. Work your way around the window. I think it will work with the rear window also. But see if anyone agrees or has another idea before you try. Or try posting this in the Type 3 section. _________________
68' Vert
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Mon Mar 07, 2005 7:56 am Post subject: |
I'd just cut out the rubber and discard it. Buying replacement rubber will be easy & cheaper than having to find & buy new glass. You just may end up cracking it trying to save the old weatherstripping. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
bmtx Samba Member
Joined: December 28, 2004 Posts: 606 Location: The Lone Star State
Posted: Mon Mar 07, 2005 11:36 am Post subject: |
I agree with 1227VW. It is also going to be really stiff if you do get it out in one piece and will probally leak. |
zipper Samba Member
Posted: Tue Mar 22, 2005 3:46 pm Post subject: |
i would say cut the rubber. they aren't expensive and fairly easy to come by (at least i didn't have problems) i know the windshield is pretty easy to put back in just using some nylon "twine" that is fairly thick and just working it around |
