karfer67 Samba Member
Posted: Tue Mar 08, 2005 5:28 pm Post subject: another speedo question |
ok what is the secret of getting that bugger out of there? in the vw work book they say to remove the fuse block but you still can't see up in there to remove it. i know there are those two clips one on each side of the speedo but how do you release it with out breaking the clips? i swear i learn something new about these type 3's everyday lol. _________________ aircooled for life (1972 squareback cal look) |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Tue Mar 08, 2005 5:31 pm Post subject: Re: another speedo question |
karfer67 wrote: |
ok what is the secret of getting that bugger out of there? in the vw work book they say to remove the fuse block but you still can't see up in there to remove it. i know there are those two clips one on each side of the speedo but how do you release it with out breaking the clips? i swear i learn something new about these type 3's everyday lol. |
the easiest way, for me, was to remove the clock first, then the speedo, then the fuel/combo gauge... removing the clock first gives you more room. I also used a long screwdriver to compress the clip on the other side of the speedo so I could push it forward.. _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Barter_Builder 69 FI/AC
Posted: Tue Mar 08, 2005 6:03 pm Post subject: |
just use your hand to squeeze the clips inwards >O< you don't need to look under the dash to do this. you could also push it foward ( as in foward toward the hood) then when you have squeezed the clips push it back ( as in back towards you or the rear of the car) I've always been able to do it this way with no prob. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Mar 08, 2005 6:16 pm Post subject: |
automatic_squareback wrote: |
And hold your mouth right... _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
