hapakel67 Samba Member
Joined: January 05, 2005 Posts: 64 Location: Minnesota
Posted: Thu Mar 10, 2005 8:23 am Post subject: Metal thickness |
Hello everybody,
I have a 67 bug, and was wondering what gauge the metal is on the body...specifically the floor of the trunk. A previous owner cut two holes for speaker...and thought about removing the speakers this spring and having the holes filled. Just curious.
Thanks,
Kelly |
VeeDubJohn Samba Member
Posted: Thu Mar 10, 2005 10:05 am Post subject: |
I've often wished someone would take a micrometer and measure an bunch of original and aftermarket parts and post it on the net. I'll be buying a micrometer for myself and will publish what I learn.
The only two things I've seen on the net are both on John Henry's pages at thebugshop.org He says that most body metal is 22 gauge and that original bumpers are .090" in thickness.
I think the best thing may be to cut the damaged section out and bring it to your local steel supply person. He should give you cold rolled mild steel about the same thickness as what you bring him. |
myb356 Samba Member
Joined: October 14, 2004 Posts: 408 Location: bay area california
Posted: Fri Mar 11, 2005 12:04 am Post subject: |
20 gauge is primarily used thoughout the car. |
Racelook Samba Member
Joined: April 07, 2003 Posts: 59 Location: Netherlands
Posted: Fri Mar 11, 2005 1:09 am Post subject: |
0,8 or 0,9 mm thicknes is that the same as 20 gauge?? _________________ B-extreme B-tuning
Racebug is comming to get ya........ Still in full resto
1974 Supa... |
myb356 Samba Member
Posted: Fri Mar 11, 2005 9:30 am Post subject: |
ok actual numbers here: 0.9 mm = 0.035856573 20 gauge is .0375 21 gauge is .0343 0.8mm= .0318 22 gauge is 0.0312 so I just actually measured a decklid and you know what? 0.0345 ....The answer is definitley 21 gauge....but since 21 gauge is not readily available as all metal suppliers I have ever seen only stock even numbers....so I personally choose to go bigger. (the only time I have ever seen odd gauge size is on certain jet aircraft made within the past twenty years) |
Posted: Fri Mar 11, 2005 4:31 pm Post subject: |
Cool...thanks for the numbers, very helpful. |
