Biill Burris Samba Member
Joined: June 08, 2009 Posts: 2 Location: Albemarle,N.C.
Posted: Sun Aug 21, 2022 5:16 pm Post subject: Does this look like a crack where the oil cooler mounts? |
Left of stud. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Sun Aug 21, 2022 5:32 pm Post subject: Re: Does this look like a crack where the oil cooler mounts? |
No!
But to be sure. Heat it with a propane torch, or a heat gun.
If it's a crack through the case. Oil should well up from the suspected crack, when heated. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Mon Aug 22, 2022 1:32 pm Post subject: Re: Does this look like a crack where the oil cooler mounts? |
Thanks, I’m hoping its not either. It’s not over the galleys so should be fine
Anyone else out there have any ideas on it let me know.
Thanks again, |
nsracing Samba Member
Posted: Mon Aug 22, 2022 1:42 pm Post subject: Re: Does this look like a crack where the oil cooler mounts? |
Did a rod kiss underneath? |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Mon Aug 22, 2022 1:47 pm Post subject: Re: Does this look like a crack where the oil cooler mounts? |
I can see something that may be a hairline crack, but then again it may not be; it's impossible to say one way or the other with just the picture provided. Your best bet is to hit it with a heat source as suggested earlier, or use some dye penetrant to see if it's cracked or not. _________________ 1960 Ragtop w/Semaphores "Inga" |
