4x4EATR Samba Member
Posted: Tue Mar 22, 2005 6:33 pm Post subject: Harbor Freight Powdercoater? |
Hello y'all! I was wondering if the Harbor Freaight Powdercoater actually works. Seems pretty cheap for $80. Is there hidden extra equipment, or is this a viable option for powdercoating small parts on my baja? Thanks in advance. |
myb356 Samba Member
Joined: October 14, 2004 Posts: 408 Location: bay area california
Posted: Tue Mar 22, 2005 9:15 pm Post subject: |
I personally use the Eastwood powder coater, but my friend has the Harbor Freight. They both work fine...all depends on how clean the parts are (glass beaded is best). All you need is a compressor with regulator capable of getting down to around 5 psi, a cookie sheet and aluminum foil. An old toaster oven is great for real small stuff. A company called Caswell sells a huge selection of powder colors at cheaper prices than Eastwood. Harbor Freight only has 4 colors. Caswell also has bulk pricing. I personally like the "almost chrome" or "silver vein" (Eastwood color chart) , but they require clear and practice not to yellow the clear. |
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Tue Mar 22, 2005 9:28 pm Post subject: |
www.caswellplating.com
Caswell has just about everything. I've used their Cermachrome. They have a formula that doesn't contain or emit the poisonous chems that the industrial Cermachrome does. It works great on exhausts and looks and wears just like what you get by sending your parts to Jet Hot. Lots cheaper. _________________ Get ready for the injection
EverettB wrote: |
Make sure it is coherent. Rodney |
mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
Posted: Wed Mar 23, 2005 5:45 am Post subject: |
Thanks for your input! I think I'll buy the Harbor Freight system and order powder through Caswell. |
gobo57 Samba Member
Posted: Wed Mar 23, 2005 9:28 am Post subject: |
can you powder cat things as large as engine tin etc. and would you have to build a box or cabinet to powder coat in without making a large mess? $80 or even $200 bucks is'nt bad. set up fees are around $100 in these parts(denver). seems a system at home would pay for itself quickly |
Kubel Nick Samba Member
Joined: August 12, 2003 Posts: 1369 Location: Fort Worth, TX
Posted: Wed Mar 23, 2005 10:34 am Post subject: |
I have a harbor freight style system and works good, tip is too big so use the smaller one that comes in the box.
Anything can be powdercoated as long as it can fit in an oven or use specific heat lamps and the item to be coated can withstand 400 degree heat. |
