74mm crank?
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
Bug-er
Bug-er is offline
PostPosted: Sun Mar 27, 2005 5:30 am    Post subject: 74mm crank? Reply with quote
anyone have any experience with these?
thinkng about using one with 90.5mm barrels but no one seems to use them, they not worth it?
Adam
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Mar 27, 2005 5:35 am    Post subject: Reply with quote
90.5x74=1904cc
Some of us use them. I'm on my second 1904. The first was 140hp and i put 80,000 miles of daily driving on it. My current has 180hp andhas 16,000 of mostly pleasure driving.
When they say the 74 will drop in with no clearencing... that's not always true. My Berg needs some minor work, but easy enough to fix.
BTW... I drive it like i stole it. So no easy life for my engines.
Glenn
iride4sue.org
Restored Bosch Cast Iron Distributors
Bug-er
Bug-er is offline
PostPosted: Sun Mar 27, 2005 5:52 am    Post subject: Reply with quote
Is going to have similar power to a 1915 motor?
spec I have at the moment
cb 044 heads 35.5x40 ported polished etc
engle 120
scat I beams
would like a bit more power but I dunno if my woney would be better spend on MSD ignition
what spec do you run? why dont many people run these setups?
turboblue
turboblue is offline
PostPosted: Sun Mar 27, 2005 5:53 am    Post subject: Re: 74mm crank? Reply with quote
Adam
Several people use 74 cranks. The thing with those cranks is that they are just as expensive as the larger stroke crankshafts on the market today.
Bigger engine for same money usually means the larger strokes are more popular.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
My Website
Shop Facebook Page
VW Tazz
VW Tazz is offline
PostPosted: Sun Mar 27, 2005 8:22 am    Post subject: Reply with quote
HAHAHAH
Laughing I drive my little 1641 like i rented it. Laughing it's like a Timex man Twisted Evil
Are we having fun yet? Well...are we?
Yellow '73 Super
Green '73 Sunroof Super
Silver '02 Turbo S
jackstraw
jackstraw is offline
PostPosted: Sun Mar 27, 2005 11:13 am    Post subject: Reply with quote
Glenn wrote:
90.5x74=1904cc
How do you figure CC? I am thinking of a 90.5x72 but I don't know what that makes. I mean I heard 90.35 made it a 1776 but I wanted to figure out how to calculate a 1835 so I can figure out what engine/how much money I am going to build
If you get confused listen to the music play!
1997 Jetta GT
1984 Diesel Rabbit
View user's profile Send private message Send e-mail Yahoo Messenger Classifieds Feedback
1955ccbug
1955ccbug is offline
PostPosted: Sun Mar 27, 2005 11:17 am    Post subject: Reply with quote
http://www.aircooled.net/gnrlsite/resource/specgeninfo/calcs.htm
bk63rag
bk63rag is offline
PostPosted: Sun Mar 27, 2005 11:21 am    Post subject: Reply with quote
Theres charts out there with all the cranks and piston sizes lke 69 crank 90.5 1776/92s 1835/94s 1915.I knew a guy with a 1904 74/90.5 he was pretty happy with it Smile there are tons of engine combos and sizes stay away from any that invove the 92s there bad news.
63 rag under construction for 15 years and counting.
jackstraw
PostPosted: Sun Mar 27, 2005 11:27 am    Post subject: Reply with quote
92's are bad... well I guess there goes that idea Laughing guess I'll stick with 90.5 and a bigger crank
1997 Jetta GT
1984 Diesel Rabbit
vwracerdave
vwracerdave is offline
PostPosted: Sun Mar 27, 2005 11:47 am    Post subject: Reply with quote
The formula to figure cc is BORE X BORE X STROKE X .0031416
90.5 X 90.5 X 72 X .0031416 = 1852.59cc
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
Bug-er
Bug-er is offline
PostPosted: Mon Apr 18, 2005 5:43 am    Post subject: Reply with quote
so does anyone know if any machining will be required
I have a new stock crank case,
90.5mm pistons for non stroker
scat I-beam rods of standard length
Type4parts
Type4parts is offline
PostPosted: Mon Apr 18, 2005 5:52 am    Post subject: Reply with quote
Use a WBX 2.1 crank and you will get a VW Factory forged 76.4mm Stroker Crankshaft with FIVE bolts holding the Flywheel on and be able to use a clutch up to 228mm.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Mon Apr 18, 2005 12:17 pm    Post subject: Reply with quote
Yes, the case and heads will have to be "opened up" for the larger cylinders to fit.
my seller feedback
rebuilt carb info = for sale
"STFU Polly and go eat a cracker!" 12-21-2012.... can't wait!
Bug-er
Bug-er is offline
PostPosted: Tue Apr 19, 2005 3:12 am    Post subject: Reply with quote
sorry I meant will the stock rods etc be ok with the 74mm crank?
will I have to clearance the crank?
someone must know going to order it as soon as I know
vwracerdave
PostPosted: Tue Apr 19, 2005 4:33 am    Post subject: Reply with quote
Stock rods should work on a 74 with no clearencing.
A 74 crank should drop in with no clearencing
The crank should drop in the case with no clearencing.
I say should, but I can't say they absolutly will. You might need to hit a few areas with a die grinder or a dremel tool. The only way to know is to mock up your engine and check all clearences.
You will have to machine the case and heads for the 90.5mm pistons.
Rome
Rome is offline
PostPosted: Tue Apr 19, 2005 6:58 am    Post subject: Reply with quote
"WBX 2.1 crank and you will get a VW Factory forged 76.4mm Stroker Crankshaft"
Is that crank counterweighted? Seems like a bargain stroker if you find one cheap from a broken shortblock; but if not counterweighted, keep the rev's to low 5's with a good balance job.
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Thu Apr 21, 2005 11:08 am    Post subject: Reply with quote
I wouldn't assume it is unless they say so.
- Scott
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- daily driver status while I work on the other two
049 > 070 > 053 > 009
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Copyright © 1996-2013, Everett Barnes. All Rights Reserved.
