markstype3 Samba Member
Posted: Sun Mar 27, 2005 2:46 pm Post subject: squareback hard start |
Hi, I have a 1600 dual carb square. Getting it stared is tough, takes a lot of cranking and pumping but once started idles ok. Also while turning over it starts to start up by the 4-5 key turns (attempts to start) and definatly is getting fuel. I think fuel pump is ok because runs smooth, maybe pressure regulator or junk plugs, coil? This is only on start up and takes les attempts thereafter. Has anyone had this problem? What should I start looking for to replace? sorry for the bad explination.
Thanks for all input. |
70fasty ITMC Member
Joined: March 11, 2005 Posts: 578 Location: Jacksonville Florida
Posted: Sun Mar 27, 2005 3:03 pm Post subject: |
possibly try checking your starter, my freinds super had a hard time starting up for a while... until he got a new starter _________________ WRX Blue 1970 VW Fastback
ITMC |
karfer67 Samba Member
Posted: Sun Mar 27, 2005 3:31 pm Post subject: |
what carbs are you using and is there an electric pump installed? on my engine with an elec pump and ICT's i turn the key till the pump turns on let it run for a few seconds then start it. fires right up everytime. when i first got this car it was hard to start then greg at greg's vw service turned the fuel T so both carbs got fuel at the same time on start up. also i replaced my cap and rotor with some new german parts and that helped out a lot. now it starts better than a lot of new cars give us a little more info on your setup. _________________ aircooled for life (1972 squareback cal look) |
Posted: Mon Mar 28, 2005 1:05 am Post subject: |
thanks for the replies. the car has the original solex carbs and I know it has a mechanical pump. Is it hard to convert to electric? I'm sure that would do wonders. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Tue Mar 29, 2005 11:37 am Post subject: |
markstype3 wrote: |
Don't need a pressure regulator. You don't need an electric pump and it's not worth the trouble, not to mention the fire hazard if you don't have a way for it to shut off if the engine stops running (say, in an accident).
Is the car a daily driver? If not then yes it could take multiple tries to get fuel to feed the carbs. Do what Everett suggested as well as valve adjust if it's time for that.
Does the car idle smoothly? Does it otherwise drive smoothly? If not and you've done the ignition checks you might want to have the carbs looked at. _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Tue Mar 29, 2005 12:22 pm Post subject: |
Thanks, and yes once started it idles real smooth and drives good too. |
Squarely67 Samba Member
Joined: April 20, 2004 Posts: 130 Location: Terrell, TX
Posted: Tue Mar 29, 2005 2:44 pm Post subject: |
Since no one has brought this up, here's a link to some info on hard starting. There are 3 pages of info. Maybe it will help.
http://classicvw.org/start1.jpg |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Mar 29, 2005 5:56 pm Post subject: |
Squarely67 wrote: |
I forgot I had that one. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
