asagodowns Samba Member
Joined: January 29, 2004 Posts: 156 Location: North Carolina
Posted: Sun Mar 27, 2005 8:33 pm Post subject: Newbie brake question |
Just acquired a 74 Thing, had the local VW mechanic go over the brakes....he replaced wheel cylinders and shoes (front and back)said they were the same as a 74 Beetle, is that the case? I had read that the brake shoes were thing specific. _________________ 74 Orange Thing
82 Diesel Caddy |
acidophilusrex Samba Member
Joined: March 27, 2005 Posts: 11 Location: Grand Junction, Tarnatia
Posted: Sun Mar 27, 2005 10:51 pm Post subject: |
The front ones are definitely the same as a Bug...the front drums are the same part number as a '67 Bug (wide-five-bolt, ball-joint suspension).
The rear? Prrrrrrobably. I've only been able to acquire Bug-ish rear shoes, but the drums can obviously acommodate something much wider. Whether they actually HAD anything that wide, I dunno.
That said, there's nothing actually WRONG with using Bug shoes on the rear...they'll still work fine on the wider, Thing-specific drums. |
Touch Nicks Thing Samba Member
Joined: May 21, 2003 Posts: 2029 Location: Alexandria, VA
Posted: Mon Mar 28, 2005 6:33 am Post subject: |
I've heard that Thing shoes are wider, I've never actually done a test to see. Like he stated there isn't anything wrong with using Beetle brake shoes. |
mattt Samba Member
Posted: Tue Mar 29, 2005 1:40 am Post subject: |
Common misconception....I used to think that also,,,,,till someone showed me better.
The fronts are 67 Bug as stated.
The rears are 181 only, unique wider drum, however, the shoes and backing plates are regular Bug. Drum is wider-increased track width, brake shoes are not.
T-3 rear shoes are wider, but you must use T-3 drums with those. |
kubelmann Samba Member
Posted: Sun Apr 03, 2005 12:08 am Post subject: |
I have two original Thing front brake set ups ( $50 each) and one complete Thing rear brake set up ( $125) These are backing plate out to the drums complete. All parts are used and have plenty of life left in them. Buy my parts and dispell all previous myths. Like Mattt, I have learned tons by taking apart fully functional Things. K-mann |
wheel607 Samba Member
Posted: Sat Nov 25, 2006 9:01 pm Post subject: |
So, is the only advantage to having 181 drums on rear of type1, wider track? Are the brake shoes the same size as a type 1? No wider shoes are available, eventhough there is about 7mm additional space for more shoe width? |
Posted: Sat Nov 25, 2006 9:45 pm Post subject: |
wheel607 wrote: |
The Thing Drums are wider, thicker and contain more heat dissipating ribs. Some time ago VW stop producing the "real' shoes. Regardless of all else, I have one set of real factory Thing brake shoes. They are not the same as the parts now avalable. For me convert to disc brakes using stock VW/Porsche parts, I have it all documented. K-mann |
