4x4EATR Samba Member
Posted: Thu Mar 31, 2005 6:09 am Post subject: Rollover damage |
I recently rolled my '77 chevy pickup while playing offroad. The only damage was the top of the cab shifted abit(leans). Doors will close, but do not line up correctly and wether seals don't seal. Any ideas? Thanks. |
John Kelly Samba Member
Joined: March 17, 2002 Posts: 477 Location: Moclips WA
bmtx Samba Member
Joined: December 28, 2004 Posts: 606 Location: The Lone Star State
Posted: Thu Mar 31, 2005 2:00 pm Post subject: |
A porta power might be able to push it back out if its not too bad. Or at least get the inner structure straight and you could skin it. |
74Standard Samba Member
Joined: March 25, 2005 Posts: 317 Location: San Antonio
Posted: Thu Mar 31, 2005 2:53 pm Post subject: Re: Rollover damage |
4x4EATR wrote: |
Take front and back windows out (they are going to break anyway if they haven't already because of the preasure) put 4x4 through front and back windows tie heavy duty come-a-long around it and big tree... slowly crank come-a-long until cab is juuuusssst past straight (you may even heat the cab post slightly if you have a torch), then release preasure (carefully that is) cab roof should be pretty close.
With out the windows in the cab it has little to no support, did this to a buddies '79, it's not pretty, but it was his horse-play truck anyway.
Other than that, cut the top off and put on new one. |
Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Posted: Thu Mar 31, 2005 4:20 pm Post subject: |
if you are not afraid of the work,.i would replace the cab with another one...
i've done 6 roll overs for friends and it's not hard. _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot. |
bk63rag Samba Member
Joined: February 26, 2004 Posts: 883 Location: Martinez ,ca
Posted: Thu Mar 31, 2005 7:14 pm Post subject: |
Yep id get a nother cab and swap every thing over or turn it in to a buggy _________________ 63 rag under construction for 30 years and counting. |
