vwdragracer Samba Member
Joined: December 02, 2001 Posts: 398 Location: Misbehavin Motorsports HQ.
Posted: Tue Nov 21, 2006 11:13 pm Post subject: |
I was talked into using a DPR crank ONCE (NEVER AGAIN) after the motor seized TWICE. I sent it to DMS to get checked out. crank was found to have a crack as well as 2 rod journals that were larger at one side than the other. The dealer I bought the crank from INSISTED i allow him to send it to DPR for inspection. 2 weeks later I recieved the same crank back with a note. "polished rod journals. nothing else wrong with crank" needles to say ... I'll never buy/use another DPR crank again. _________________ Going fast in a VW because to do so in anyything else is boring |
craigman Samba Member
Posted: Wed Nov 22, 2006 12:07 am Post subject: |
Me personally, i'd rather use a china crank over a Demello. A buddy of mine had a Demello crank in his 2007. It kept eating bearings untill they found out that it was bent. Motor was professionally built by local builder.
But this is only what i've seen. It sounds like most people have had good luck with them. Maybe this one just slipped thru the cracks one day.
Anyways, just my $.02 worth.
Craig |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Wed Nov 22, 2006 1:53 pm Post subject: |
I only use DeMello. If you have a good crank, just send it to them _________________ die schwarzen Schafe #666 |
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
Posted: Wed Nov 22, 2006 4:52 pm Post subject: |
RIS wrote: |
craigman wrote: |
Me personally, i'd rather use a china crank over a Demello. |
Nobody is perfect, but that is a bold statement! |
RIS,
it's not a "bold" statement. This just has been MY experience.
I myself have seen three "china" cranks used without any problems at all. And i am currently using a "china" 69mm c/w crank with no issues as of yet.
But like i said, the one and only Demello crank i have seen in use was bad. The motor was put together by a professional shop that builds motors and sells parts worldwide.
But like i said, it could have definately slipped thru quality inspection one day. Thats pretty easy if you factor in human error.
Like i said, this is only what i have personally seen.
Take it for what you want.
Craig |
Bugman Jeff Samba Member
Joined: May 20, 2004 Posts: 636 Location: Evansville, WI
Posted: Wed Nov 22, 2006 5:28 pm Post subject: |
Whats the average cost of a DPR/DMS crank? _________________ Restorer of Porsche Speedster 80486 |
TroyG Samba Member
Joined: August 14, 2006 Posts: 192 Location: Nevada Texas
Posted: Wed Nov 22, 2006 5:46 pm Post subject: |
Craigman
I would like to know who the builder of this 2007 motor you keep referring to. Sounds to me either your buddy or the builder dropped the crank or ran over it with a tank.
You obviuos have not seen a post that was going around last week regarding a motor that exploded on me with a DEMELLOW crank in it.
http://www.thesamba.com/vw/forum/viewtopic.php?t=201503
When I pulled the rest of the motor apart I sent the crank into Bob to have it checked out. Before sending it to him I called him and told him who I was and showed him the pictures that you are looking at. He told me that most likely the crank would be cracked or bent so bad it would not be repairable. He also said the crank looked like it had been through world war 1,2,korea,nawm & desert storm so don't be supprised if you have to start over with a new one.
Well I was supprised to find out after all the beating it took when the motor let loose, the only thing that was wrong with it was it was bent .005 and the jurnals needed cleaning up.
PUT YOUR CHINA JAP CRANK THROUGH THAT AND THEN WILL TALK.
I have listen to you wine and mouth off about your buudys motor long enough. Its not your motor and you were not there when it was built.
What happen to the crank after it left Bob's shop?
Shipping?
Delivery?
Your Buddy's handling?
Your builders Handling?
Did his builder use the correct bearings?
Was the crank set on the dowel pens correct?
Over torqued?
Under torqued?
Rods balanced?
Flywheel balanced?
You say it keep eating bearings how many time did the builder rebuild the motor before he thought, man there may be a problem here.
A real professional engine builder would have found it the first time round not just keep putting it back togeather.
In closing don't speak unless you have first hand experiance and its your parts and you built the motor because theres no way you could know.
DeMellow Cranks are without a doubt one of the BEST on the market.
That my opinion but what do I know. ( I BUILD MY OWN RACE ENGINES ) |
Posted: Wed Nov 22, 2006 6:08 pm Post subject: |
TroyG wrote: |
Craigman
Shipping?
Delivery?
Over torqued?
Under torqued?
Rods balanced?
Flywheel balanced?
Wow Troy, didn't know you took things soo personally.
Like i said earlier, this has only been my experience. I even stated that the crank could have slipped pass quality inspection that day. Things happen. People make mistakes.
I wasn't "whining" i was responding to a post. And in every post i made, i didn't degrade anyone, i was simply just stateing what i have personally seen. There was never any disrepect towards anyone. If you take it that way, that's your problem.
By the post you made in reply to NSR, (which by his post, i seem to agree with alot of what he says) which was, "My God we finally agree on something" seems like you have a hard time agreeing with anyone. Hmm,, personal problems maybe?
Anyway, like i said before, i never mean disrespect towards any post. The starter of this post was asking about DMS and DPR cranks. I was just offering what i have personally seen and experienced. Thats one of the great things about the internet and places like the Samba. People can ask questions about certain items and get peoples "opinions".
Again, take it for what you will. If you have any more problems, your more that welcome to PM me.
Craig |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Nov 22, 2006 7:10 pm Post subject: |
This thread has turned into a Ford vs. Chevy pissing match. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
TroyG Samba Member
Posted: Wed Nov 22, 2006 9:17 pm Post subject: |
vwr
Your right and im sorry for getting into it.
DeMellow makes a great product is all I should have said. |
Posted: Wed Nov 22, 2006 10:00 pm Post subject: |
Bugman Jeff wrote: |
Whats the average cost of a DPR/DMS crank? |
Jeff,
here's DeMellos's price list page: http://www.demellocranks.com/Price%20List,%202006.htm
69mm c/w welded crank is $125 and a 82mm c/w crank is $325
I don't have a web address for the other brand.
Hope this helps!
Craig |
mark tucker Samba Member
Posted: Mon Jan 03, 2011 3:55 pm Post subject: |
old post but what the hell. Ive got an 78 dpr on the way and was wondering just what to do. clickrerreerrrrrrrrrrrrsnap ! ok the top of the can of openion worms is open to the masses.hmm ever notice there are asses in the middle of the masses?? I'm fixen to build another stroker, why I dont know, board I reckon, or just plain nuts. my 2028 has a new case(last year) wedge port mofoco 042 heads.scat cast 78.8 crank str8 gears,thin slip in berg 90.5 cylinders(slip into machine 88 holes).the spair motor I qam fixen to build I was going to us an old as 41 stroker clearanced 60 linebore,70 thrust.case.and what ever heads I come up with. I have a new set of AA pistons92's. the scat crank was in thei linebored case for 5 years as a 1874,(87mmx78. worked great. so what my brain is trying to figure out now is.do I put the dpr crank in the linebored case with the 90.5 pistons? and put the 92's in the new case with the scat cast crank that scat says good for 150 hp. or put the dpr crank in the new case with the 92mm pistons,and turn the linebored case into the 2028?and build a set of heads for it? hmm what to do? has any body had any problems with the volkstrokerIII 78.8 cranks? I have run this very hard for about 6 years and always with good oil.there was no wear at all last year when I tor it appart to change the case &use biger cylinders.. I reckon what I am pondering on is this dpr crank all that much better than the cast scat? If I use the dpr in the new case I will probably use a 5.5 rod so I dont have to cut the cylinders shorter like I did the 90.5's..
hopefuly when the crank gets hear by looking at it and checking it out that will help in the dission. so reach in the can and pull out some worms and lets hear your thoughts. I like a good debate even when the masters are involved . |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Mon Jan 03, 2011 5:09 pm Post subject: |
Is it a welded DPR? If so.....tighter deck than your cast crank.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Mon Jan 03, 2011 5:25 pm Post subject: |
I just finished running the 24 hours of LeMons race on New Years Eve, running a 74mm DPR Crank/flywheel combo. We RACED this motor continuously for 24 hours, and logged over 1200 miles on it without Any Mechanical issues on the entire car. The motor performed flawlessly.
_________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket!
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Mon Jan 03, 2011 5:58 pm Post subject: |
I must add if someone were to logically look over this thread they would understand that BOTH DPR and DMS crankshaft are both very good cranks for the money. Human error comes into play on both sides and that is all.
China Cranks 3rd. LOL _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE) |
Posted: Mon Jan 03, 2011 6:10 pm Post subject: |
how much tighter than +.003?? with .040 copper head gadget
and this thing just got hear. Im looking at it now, not imperssed at all.If someone had brought this into my shop I probably would of told them to throw it away. stuposidly it has been balanced by dpr when they did it. so I reckon I probably should not "clean "it up any. I dont know if I have seen worse or not, but I reckon it aint the looks that count. but dam,I wish I still had a balancer.this thing would go on a diet and get a makeover.they dont stamp a date or sr# on these things? just dpr 78. I reckon drilling the throws would be to much to ask for or lead in trough's.ow well, it's mine. it's the first one I have had my eyes on(welded counter weight &welded stroker).now to figure out what to do with it. all used used parts or slighty used ,great almost new used parts.
and for richard petty, did you have fun??? where did you place? what's in your motor? 74 is kinda short stroke but it still helps out a bunch.
I gess I should of started a new thread scat volkstrokerIII cast vs a dpr welded stroker |
bartman Samba Member
Joined: February 22, 2004 Posts: 767 Location: palatka, fl
Posted: Mon Jan 03, 2011 8:15 pm Post subject: |
I have a dpr 78. It's stamped DPR 78 and nothing else. It's been balanced but that didn't really matter as I had my entire rotating assembly balanced as a unit. This should be done anyway to eliminate tolerance stack.
It's a welded stroker so it looks like it's been welded on but the journals are the right size and they're where they should be so appearance really isn't an issue with me. I can't even see it now that the engine's together |
Posted: Mon Jan 03, 2011 8:43 pm Post subject: |
yup I know , I reckon I am just a tad spoild from all the crower cranks,rods,rockers,cams & lanauti cranks& lifters & bryant cranks,but mostly a pile of crower cranks that have gone out my shop. I have realy never seen any thing like this in my life well 1 effed up wanna be promod crank that had 1/4"x 6"long the width of the counter weight, strap steel welded to the counter weight for balancing(morons must of never heard of tungstin slugs.)came into our shop,and went back out. and if I remember corectly it was a 4.75 stroke . |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Mon Jan 03, 2011 8:45 pm Post subject: |
jbbugs wrote: |
I just finished running the 24 hours of LeMons race on New Years Eve, running a 74mm DPR Crank/flywheel combo. We RACED this motor continuously for 24 hours, and logged over 1200 miles on it without Any Mechanical issues on the entire car. The motor performer flawlessly.
JB,
Your car makes me smile. Somehow a colorful Herbie comes to mind. I know I know way different years. I dont care though.
My first crank is an 82mm Scat crank. No problems, spec-ed out all fine. If the price were right Id probably buy another one with no second questions nor doubts. But now I normally only buy, suggest and run DPR cranks. The quality and inspection before they are sent out gives me peace of mind. If Jose was out of xx crank, Id go and buy a Demello crank with no questions nor any doubts. Cause I know Bob pays attention as well. These are both professionals at what they do. There is no real comparison. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Mon Jan 03, 2011 9:07 pm Post subject: |
mark tucker wrote: |
Im looking at it now, not imperssed at all. |
Ask Jake Raby what he thinks of DPR crankshafts! _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
