squarewerks Samba Member
Posted: Tue Apr 05, 2005 7:38 am Post subject: Rear drum locked up |
I was traveling down a road in my neighborhood and just dove into a huge pothole and when i hit it it locked my rear drums up and i had to drive home that way. What could have caused this, when it happened i tried pulling my E-brake but it was so tight i couldn't even do that! whats up guys? '70 square with 4 lugs. |
redbug74 Samba Member
Joined: June 15, 2004 Posts: 292 Location: Far West Texas
Posted: Tue Apr 05, 2005 1:40 pm Post subject: |
Maybe when you dove into the pot hole something (the ground, debris, the edge of the pot hole) went as far up as the spot where the e-brake cable exits the pan or where it enters the backing plate and it broke or bent the cable. This put tension on the cable/e-brake handle thus locking up the rear brakes. Check the bottom of your car, especially where the e-brake cable exits the pan/enters the drum. Or the ratchet mechanism on your e-brake was all loose and the sudden jerk from the pot hole made the ratchet/teeth come loose and slip all the way down, eliminating the upward stroke of the e-brake handle. Pull up the e-brake boot and try to determine where things are. Hope that helps. |
Posted: Tue Apr 05, 2005 6:55 pm Post subject: thanks |
thanks i will check it out |
