Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Thu Apr 07, 2005 7:10 pm Post subject: |
blankmange wrote: |
I had thrown that tid-bit in there to show what a great motor you have, even when it runs on only 3 cylinders... |
I know, I'm just giving you shit. _________________ OGST
Samba Member #4862 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Apr 07, 2005 7:12 pm Post subject: |
Mr. Bubblehead wrote: |
Russ Wolfe wrote: |
You might try putting a 250 ohm resistor in series with the head temp sensor. This will move the fuel mixture up range. |
Funny you should mention that, I've already busted out the resistors, playing around with different values on the temp sensors |
This was an authorized VW repair. That is how I knew the value.
There was one of the factory ones on Ebay a whole back. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Thu Apr 07, 2005 7:13 pm Post subject: |
Russ Wolfe wrote: |
You might try digging up a T-1 FI pressure regulator. They were adjustable, and had vacuum port.
Variable with engine load.
Something to play with. |
Like this one?
http://www2.cip1.com/ProductDetails.asp?ProductCode=BOS%2D0%2D280%2D160%2D200
I think I may have one, actually...hmmm..... _________________ OGST
Posted: Thu Apr 07, 2005 7:34 pm Post subject: |
Yep. Inside that vacuum port is a small "Metric" allen screw. The factory set then, then kinda crimped them. They can sometimes be turned. Screwing it in will increase the pressure. IIRC, 1 turn was about 2 PSI. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Thu Apr 07, 2005 8:44 pm Post subject: |
Well cool, it looks like I have a bunch of stuff to play around with and mess up tomorrow. I'll post what works and what doesn't. _________________ OGST
Posted: Thu Apr 07, 2005 8:54 pm Post subject: |
Well cool, it looks like I have a bunch of stuff to play around with and mess up tomorrow. I'll post what works and what doesn't. |
Darkside D-Jet _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Thu Apr 07, 2005 9:00 pm Post subject: |
Russ Wolfe wrote: |
Darkside D-Jet |
I'm no purist, that's how I roll! _________________ OGST
seans67 Samba Member
Joined: October 06, 2004 Posts: 453 Location: End of the Road, Alaska
Posted: Thu Apr 07, 2005 9:07 pm Post subject: |
Definitely interested in what you come up with.
Will you check with a wide band O2 when you finaly get it dialed in where you want? _________________ Sean
'71 Squareback '71 Porsche 914 ‘80 Camper '87 Syncro Weekender 1.8T '87 Wolfsburg Weekender '97 Toyota Land Cruiser ‘03 Audi A6 Quattro 3.0 ‘04 Audi A4 Avant Quattro 1.8T ‘05 Audi A4 Quattro 3.0
‘06 Porsche Cayenne Turbo S |
Posted: Fri Apr 08, 2005 3:30 pm Post subject: |
OK, well after dinking around with the timing, fuel pressure, and some MPS adjustments the car runs and drives like a fucking rocket. My question now is how much total advance is too much? I know I've got it set at well over 32º when it gets up to 3000 RPM, but I'm running premium fuel and I'm not hearing any pinging so I don't think that there's any detonation going on. My temp gauge (oil temp, it's all a got) is reading just a hair hotter than it normally does, I just don't want to be burning up any valves or pistons or anything. BTW, I am running a Porsche 914 distributor with vacuum advance & retard (the retard side is capped off though). I don't know if this dizzy is any different than a stock type 3 one. _________________ OGST
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Apr 08, 2005 7:21 pm Post subject: |
I would back that timing down if I were you. I'm not a big fan of running the timing one iota more advanced than specs. Maybe it's just the VW training, but I had the timing thing bashed into my head. I wouldn't risk it.
As to the distributor, timing curves for BOTH #1 amd #3 are equally important. I remember that the stock distributors on Type 3s had a slight retard for #3. Wolfe would probably know offhand what the spec is- I can't remember. I'd get a stock Type 3 distributor if I were you. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri Apr 08, 2005 8:07 pm Post subject: |
What is the advance supposed to be at for a stock 1600 with d-jet, Is it just set at 0deg at idle and that's it?
32deg seems like a lot. _________________ Sean
Posted: Fri Apr 08, 2005 8:23 pm Post subject: |
At idle early FI timing is supposed to be at 0º, later systems were at 7º BTDC I think, but I'm talking about total advance, not timing at idle. Mine's set at around 9º BTDC at idle right now. _________________ OGST
Posted: Sat Apr 09, 2005 11:11 am Post subject: |
[email protected] wrote: |
As to the distributor, timing curves for BOTH #1 amd #3 are equally important. I remember that the stock distributors on Type 3s had a slight retard for #3. Wolfe would probably know offhand what the spec is- I can't remember. I'd get a stock Type 3 distributor if I were you. |
2 degrees on the dist. shaft acording to this docutment. that would be 4 degrees crankshaft.
http://classicvw.org/gallery/my_misc/pic00005 _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
kenikh Samba Member
Joined: October 28, 2005 Posts: 89 Location: Seattle, WA
Posted: Fri Oct 28, 2005 11:31 pm Post subject: |
I love this thread; this gives me hope that I can one day soon replace the DCNFs that replaced the FI on my '71 Fastback. It has a 78mm crank and 88mm pistons, so it's a bit bigger than a 1776. Looks like I should go ahead, take the plunge, buy a complete FI and give it a shot.
Thanks for the courage! _________________ >Kenik<
- 1971 Fastback Resto Hotrod
- 1969 Porsche 911S
"Now, to put a water-cooled engine in the rear and to have the radiator in the front, that's not very intelligent."
-Ferry Porsche |
Kenaneu Samba Member
Joined: March 20, 2005 Posts: 156 Location: San Francisco, CA
Posted: Sat Oct 29, 2005 5:40 pm Post subject: |
If you're going with something bigger than 1776, you really should consider getting some 2.0 litre injectors to go along with your FI setup. You should be able to find some porsche 914 2.0 d-jet injectors floating around somewhere. |
kenikh Samba Member
Posted: Sat Oct 29, 2005 6:22 pm Post subject: |
Yeah, it's a pretty hot 1.9L. Good idea on the injectors. _________________ >Kenik<
- 1969 Porsche 911S
-Ferry Porsche |
Posted: Sat Oct 29, 2005 7:10 pm Post subject: |
Be sure you really do pay some respect to the talk about cams too... You could be in for a seriously long and frustrating process if you're cam is too big... |
kenikh Samba Member
Posted: Sat Oct 29, 2005 9:29 pm Post subject: |
Engle 110; I've been told it's possbile. I'm crossing my fingers. _________________ >Kenik<
- 1969 Porsche 911S
-Ferry Porsche |
kenikh Samba Member
Posted: Wed Nov 02, 2005 11:07 am Post subject: |
I've been thinking more about this issue and am beginning to wonder if an "off the shelf" cam is even the right way to go to improve the performance of EFI on non-stock motors. Since Jetronic uses the intake pulse as the fueling trigger, it seems obvious that a cam with a large degree of overlap and thus greater intake side reversion, is going to make it tough going getting the FI to work correctly. Since it is this reversion that is muddying the intake signal, mitigating this effect seems like it would be design criterion number one in building a good big-bore FI motor.
So the question is, perhaps a custom cam is the solution, especially for these larger motors. Off the shelf cams seem to have been designed from day one with carburetion in mind, with no design consderations set aside for taking into account intake side reversion characteristics. A custom grind cam with minimal overlap, but higher lift to improve cylinder filling for the larger displacement could make performance on big motors better than a stock cam and would minimize reversion downside, as well.
I think it would take some serious calculation to decide how much overlap you can design into the cam, but I'd bet starting with the Engle 110 (which was proven to work with some problems by Mr . Bubblehead) and working back toward stock might be a good way to go.
Thoughts?
BTW, here's a great Camshaft design FAQ _________________ >Kenik<
- 1969 Porsche 911S
-Ferry Porsche |
Posted: Mon Dec 19, 2005 6:39 pm Post subject: |
Russ Wolfe wrote: |
Yep. Inside that vacuum port is a small "Metric" allen screw. The factory set then, then kinda crimped them. They can sometimes be turned. Screwing it in will increase the pressure. IIRC, 1 turn was about 2 PSI. |
Sorry to bring an old thread back here, but I am thinking about getting one of these pressure regulators for my current project. Is the adjustment you describe above for the actual overall fuel pressure, or that of the additional fuel supplied under vacuum? Just want to be sure I'll be able to adjust the overall fuel pressure before I buy one of these...
Thanks! |
