Speedsterboy Samba Member
Posted: Thu Apr 07, 2005 4:13 am Post subject: Had enough! |
I have a 64 Square that has the bone stock detailed 1500 single carb. I converted the car to 12 volts, should I have changed the 6 volt choke mechanism in the carb to a 12 volt one? This car has never run perfect despite having replaced everything mechanical when restored. It never accelerates smoothly and is always reluctant to idle during warm-up. My mechanic is very good and have always maintained my other VW perfectly, strange because it may run rough but this car is so reliable despite these issues. I am considering changing the 009 as it might be a new 'faulty' item..any other suggestions?
Thanks,
AL
https://www.thesamba.com/vw/gallery/pix/156805.jpg |
Zarana-X Samba Dreadnok
Joined: September 03, 2004 Posts: 372 Location: How could hell be any worse?
Posted: Thu Apr 07, 2005 6:59 am Post subject: |
The 009 with a single center mount carb is a horrible combination. I have a 009 and the Weber progressive carb and am having the same problems you described.
My 2 part solution (as money allows) is to get a new vacuum advace distributor, and to get dual Weber ICT carbs. _________________ "In order to create, you have to destroy." |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
Posted: Thu Apr 07, 2005 7:09 am Post subject: |
I would change to a 12v choke.
If it doesn't idle well during warm-up, maybe you already burned up the 6v choke? Is the single carb. manifold heat riser blocked?
Yes, I would try to find the stock distributor. You have a '64 so is it an "N" model or is it a special Australian model? _________________ How to Post Photos
vweater1 Samba Member
Joined: January 08, 2004 Posts: 349 Location: LakeView Terrace, California
Posted: Thu Apr 07, 2005 12:45 pm Post subject: |
Everett is right. Either use the stock dizzy or IMO get a 019 or a 010 if you have a high performance engine which you don't.Besides a 009 is mostly used on a type1. From what I was told they don't advance very well on a type 3 motor . I have a 019 and just a couple of months ago had the same problems you where having . The car didn't advance properly and it idled rough. Now it advances great and smooth, I use my 71 sqbk as my daily driver now from North Hollywood to Santa Monica everyday. |
Posted: Thu Apr 07, 2005 7:40 pm Post subject: |
Thank you all. I am having the distributor replaced...see how we go! |
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Thu Apr 07, 2005 7:45 pm Post subject: |
vweater1 wrote: |
...Besides a 009 is mostly used as a paperwieght... |
I've got one I took the guts out of, polished up, and use as an ashtray out in the shop _________________ OGST
Samba Member #4862 |
Posted: Sun Apr 10, 2005 2:41 am Post subject: |
Thanks all, it does appear that the 009 was the culprit! it is running so much better now but still not perfect, it still has a slight reluctance on take-off and one other thing, when one switches the ignition on, nothing happens but complete silence until after 4 seconds the starter cranks over...? Is this potentially a part of the problem?
Thanks,
AL |
hoss Samba Member
Joined: May 01, 2003 Posts: 788 Location: San Jose, CA
Posted: Sun Apr 10, 2005 9:27 am Post subject: |
al,
which dizzy did you end up replacing the 009 with? _________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
Posted: Tue Apr 12, 2005 6:29 am Post subject: |
I replaced it with the original Type3 distributor with new poits etc...running soo much better. Still having a little fuel delivery issue (on take-off) via the fuel pump my mechanic claims...any other suggestions from anyone?
Thanks,
AL |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Apr 12, 2005 5:30 pm Post subject: |
Mr. Bubblehead wrote: |
vweater1 wrote: |
I've got one I took the guts out of, polished up, and use as an ashtray out in the shop |
Whats that I am kicking under the desk Oh, its an 009 _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
wynsquezr Samba Member
Joined: March 08, 2005 Posts: 163 Location: 38d N 121d W
Posted: Tue Apr 12, 2005 7:10 pm Post subject: Russ's 009 soccer ball |
So now I know what to do with this 009 I got told I needed when I went to the dual weber 34's,now to go find a set of point ,drop the oem FI dizzy in and drop kick the 009 into next week |
Posted: Tue Apr 12, 2005 7:46 pm Post subject: Re: Russ's 009 soccer ball |
wynsquezr wrote: |
Those points should be very easy to find. They are the same as T-1, T-2. T-3, early Rabbits, golf.
Any lat VW that doesnt have electronic ignition. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
tomnotch Samba Member
Joined: October 22, 2004 Posts: 788 Location: Key Peninsula, Wash.
Posted: Tue Apr 12, 2005 8:40 pm Post subject: |
the fuel pump will NOT cause this except in extremely rare conditions. The float bowl has fuel in it (I hope!) and the accelerator pump will draw fuel from this as will the circutry of the carb. I doubt that your car would even run if the fuel pump was not pumping. The odds of it not filling the float bowl are slim.........
What's the condition of the accel pump?
What's the float level?
And your delay on start is caused from one of three things, maybe all. A dying igntion switch, hi resistance in the wiring, a dying solenoid on the starter.
al9 wrote: |
Thanks,
AL |
_________________ Tom
DVKK
DSD, Dark Side Disciples
Progenitor |
Posted: Tue Apr 12, 2005 10:19 pm Post subject: Re: Russ's 009 soccer ball |
Russ Wolfe wrote: |
wynsquezr wrote: |
Any lat VW that doesnt have electronic ignition. |
Igot points,somewhere in the shed, I just got to get them and the original dizzy in same place and time. Have petronix in 009 but was told same unit won't cross over to FI dizzy which I understand is basically same as050 with space and cam for inj. trigger points |
Squarely67 Samba Member
Joined: April 20, 2004 Posts: 130 Location: Terrell, TX
Posted: Wed Apr 13, 2005 6:18 am Post subject: Re: Russ's 009 soccer ball |
wynsquezr wrote: |
One might consider drop kicking the 009 into one's tool kit in the trunk as a spare just in case. It may be far from perfect, but it might come in handy some night. If not for you, then maybe someone else. I feel a little better knowing if my distributor or electronic ignition decides to bum out, I've got a spare to limp home on. |
86syncro Samba Member
Joined: February 04, 2005 Posts: 162 Location: Lexington,KY
Posted: Fri Apr 15, 2005 8:28 pm Post subject: |
Did you say that you were running a single carb?
If so, get some baby dells, dual Solexs, or Weber ICTs to put under there with a SVDA distributor. Stock or aftermarket vaccum dist is better than a 009.
I had a '72 Squareback with a 009 and Dual ICTs. It ran good but it had a hesitation at take off. I sold it before I switched the 009 out, but I'm sure it was the culprit.
STOCK CARBS ARE BETTER THAN ANY AFTERMARKET IF YOUR LOOKING FOR DRIVABILITY!!! |
Posted: Sat Apr 16, 2005 9:37 am Post subject: |
Running dual 34's how did you supply vaccum to the dizzy,would like to go back to stocksvda because of hesitation ,etc. what about vacuum supply. 3/8 balance pipe between intakes? |
