meinvw Samba Member
Joined: October 24, 2003 Posts: 828 Location: Georgia
Posted: Thu Apr 07, 2005 8:03 am Post subject: Best way to clean aluminum rims? |
I have 2 sets of aluminum rims that need cleanning, one set was on a vehicle in the woods for 3+years, the other was cleaned by PO but only on the front, they have 30 years of grime caked on back.
Any ideas on the best way to clean without damaging? Thanks in advance. _________________ The memories of a man in his old age, are the deeds of a man in his prime.
Quando Omni Flunkus Moritati !
73 High roof, 79 hr, 72 hr, Mr magoo buggy, 72 westie, and then there is the wc junk...
www.fullmoonbusclub.com
Want a hazet tool kit or hazet buddy ,plaid stool/bucket, or a drive away tent (later model, do not want og tents) Trades on these parts since I am a broke mo-fo..... |
RareAir Samba Member
Joined: May 11, 2002 Posts: 12609 Location: 18 miles North of the border
Posted: Thu Apr 07, 2005 5:02 pm Post subject: |
Hand wash the wheels to get most of the grime off. Use engine degreaser or some alternative wheel cleaner. Then after drying, just start applying Mothers Aluminum polish. Slow & tedious, but you'll eventually get it done. You can also try using 1000-1500grit wet/dry sandpaper to get most of the grimy residue off. _________________ 1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
Sent from my iPhone 9S |
markm Samba Member
Joined: July 21, 2003 Posts: 995 Location: Seattle, Via Beautiful El Sereno CA.
Posted: Thu Apr 07, 2005 8:47 pm Post subject: |
| Squirt some modern wheel cleaner and then use a pressure washer. |
meinvw Samba Member
Posted: Fri Apr 08, 2005 5:32 am Post subject: |
Thanks all, I have tried the greased lightning automotive, and a few others. But looks like I will be doing it by hand. So much for being lazy! _________________ The memories of a man in his old age, are the deeds of a man in his prime.
Kangarooboy Samba Member
Joined: January 01, 2005 Posts: 13 Location: Seattle, WA
Posted: Wed Apr 27, 2005 9:55 pm Post subject: Similar question |
I'm wanting to polish my Rivieras, did they have a clearcoat on them or can I just go to town with the Mothers aluminium polish?
Thanks! |
nobrakes Samba Member
Posted: Thu Apr 28, 2005 4:36 am Post subject: |
Check back when your done, you have a BIG job ahead of you doing it by hand. Unless the wheels are rare just buy new ones or roll them crusty. _________________ If your not workin or cleanin your not looking hard enough. |
Nid Samba Drama Queen
Joined: August 25, 2003 Posts: 1539 Location: Seattle, WA
Posted: Thu Apr 28, 2005 9:42 am Post subject: |
What prevents you from using a low speed hand held buffing wheel with the polish? Why by hand? _________________ My, you've been naughty. How.....Delicious.
You're such an inspiration for the ways
That I'll never ever choose to be
Oh so many ways for me to show you
How the savior has abandoned you
Fuck your God, Your Lord and your Christ
He did this
Took all you had and left you this way
A Perfect Circle - Judith |
canbug Samba Member
Posted: Sun May 01, 2005 1:47 am Post subject: |
I have used oven cleaner before with very good results. If you go this way, spray it on and wipe it off a minute later and repeat. If you leave the oven cleaner on for a longer perod of time it will start to eat/pit the wheels. Good luck. _________________ Water is for toilets.
Her 56 KG
His 56 KG
75 SB.."The Booger Bug"
78 Hightop Camper, sold
69 Single Cab, my new daily driver. |
sk8brd75 Samba Skateboarder
Joined: November 17, 2003 Posts: 76 Location: 57 in the 805
Posted: Sun May 01, 2005 7:20 am Post subject: |
| canbug wrote: | | I have used oven cleaner before with very good results. If you go this way, spray it on and wipe it off a minute later and repeat. If you leave the oven cleaner on for a longer perod of time it will start to eat/pit the wheels. Good luck. |
Pitting makes them lighter. Should shave a good half-second off your quarter mile.  _________________ www.slovolks.com
1957 Type 1 Cal-Look
1965 Type 2 Standard |
coad  Samba Scapegoat
Posted: Sun May 01, 2005 7:38 am Post subject: |
Oven cleaner might be a bit too harsh.
The hardware stores sell a spray-on cleaner for aluminum screendoors and windows that removes the heavy oxidation without doing damage. It won't get the wheels anywhere near where you want them, but it will get rid of the worst of it, and give you a good place to start. |
meinvw Samba Member
Posted: Mon May 02, 2005 5:33 am Post subject: |
Thanks all, Had someone want the wheels so I sold them. But great info I am sure I will need it again down the road. Ah, wait, the Ansens on my 62 need cleaning, I guess its back to work! _________________ The memories of a man in his old age, are the deeds of a man in his prime.
squidman Samba Member
Posted: Fri May 06, 2005 10:54 pm Post subject: aluminum rim polishing |
| Just short of having a shop polish them at about 1,000 rpms with some Tripoli bars and a cotton wheel. Try using wet/dry sandpaper at 1200 grit or better with a light oil if they are already smooth. Then follow with any commercial polish for aluminum. If they are cast, don't waste your time, just clean em with simple grean or similar. |
