BIG ILND 53 Samba Member
Posted: Sun Apr 10, 2005 4:20 am Post subject: Tunnel Restoration? |
Can someone give me info on how to get into the tunnel section for a little restoration? Do I need to go in from the top section or can I go in from the underside of the pan/tunnel? Has any of you fellas dunn something like that? Info greatly appreciated!
Thanks
CCC |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sun Apr 10, 2005 5:23 am Post subject: |
Grab a plasma cutter or a diegrinder. Seriously, you'll need to cut in some access holes, that's the only way. Don't cut it from the bottom, cut in from the top, it's easier to cover up with carpet when you're done. What's in the tunnel that needs restoring? Clutch, accelerator or choke cable? Fuel line? _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
luis Samba Member
Joined: December 06, 2003 Posts: 320 Location: Northern California
Posted: Sun Apr 10, 2005 11:19 pm Post subject: |
Cut from the side to peer in to the left and right. Cutting right on top of the tunnel does not let you see so good left to right. I used a cutting disk to make square incisions as in the diagram below. After the three sided cut was made, I used a hammer and pry bar to pull it down.
Then you can use the hammer to close it back up, then weld it shut. I would only place a few spot welds near the front pedeal cluster in case you need to get in there if its a pre 67 bug. Not all pre 67 bugs came with that option, and its a good idea if you want to get in ther later. |
