shayme Samba Member
Joined: January 15, 2004 Posts: 62 Location: San Diego CA
Posted: Sun Apr 10, 2005 8:43 pm Post subject: Dual IDF 40 Woes!! Please help! |
Hey all,
I'm having some trouble w/ my carbs and I 'd appreciate some advice. Here's where I"m at:
Left Carb:
Major vacuum leak in left carb between intake manifold and carb. Today I replaced the gasket and it still has the same leakage. Couldn't put carb flat on ground b/c there is some hardware which gets in the way of this. But I did put it on the intake manifold w/o gasket and there is some movement from front left to rear right. So I"m thinking there is some uneveness there. Can't tell from looking at the carb bottom though. I hope that the manifold isn't warped, didn't look like it. Oh and also, the RPMS actually decrease when carb cleaner is sprayed on it, almost dies rather than speeding up which I've been told is what happens.
Right Carb:
No. 1 cylinder idle mixture screw does not have any effect on the engine when bottomed out or removed. I have taken both carbs out and removed idle jets and mix screws, blew out circuit's w/ compressed air very well in all barrels.
So when I reinstalled the carbs, I still have the left vacuum leak and the No.1 cylinder idle mixture screw isn't having an effect on anything.
My thoughts are that I need to remedy the vacuum leak, but can't seem to locate it. And second, that I may need to rebuild the right carb? Any suggestions greatly appreciated. I'm getting tired of not being able to drive the squareback! |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Mon Apr 11, 2005 8:39 am Post subject: |
Your #1 barrel issue is the same as my #2 barrel issue (idle adjust doesn't do its job). Can't tell you what to do as I have no clue but two sources have told me to get a carb rebuild kit. I'd like to understand why this happens. Does the seat /valve have deposits on it that physically keep it from seating? Or does the seat/valve get pitted and need machining/replacing? Why? _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
