Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Mon Apr 11, 2005 5:53 pm Post subject: Fuel injected gas mileage |
IS 37 MILES PER GALLON NORMAL ??!!? _________________ OGST
Samba Member #4862 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Apr 11, 2005 6:11 pm Post subject: |
You are too lean...... _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Mon Apr 11, 2005 6:43 pm Post subject: |
Mr. Bubblehead wrote: |
IS 37 MILES PER GALLON NORMAL ??!!? |
It would be nice to think so wouldn't it? |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Mon Apr 11, 2005 7:28 pm Post subject: Re: Fuel injected gas mileage |
dayumm! _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Apr 11, 2005 9:11 pm Post subject: |
It's a bit on the high side. You MAY be a little too lean. Try to get a sniffer on it. Too lean will make rather quick work of your engine. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Anniehum Samba Member
Joined: November 23, 2003 Posts: 1197 Location: Kingston, Washington
Posted: Mon Apr 11, 2005 9:45 pm Post subject: |
I run consistanly 26-27 mpg. I check it every fill up.
Cheers _________________ Ho'oponopono |
Posted: Tue Apr 12, 2005 4:33 am Post subject: |
Well I had a feeling that it was running lean, I haven't had a sniffer on it yet, but the plugs are a nice grayish-brownish color. I always thought that the plug color test was an accurate way of determining proper fuel mixture. Or is this only for carburated engines? _________________ OGST
SquareD Samba Member
Joined: August 15, 2002 Posts: 266 Location: California-USA
Posted: Tue Apr 12, 2005 3:42 pm Post subject: |
Before I pulled the FI engine in my 1970 Squareback, I would get about 32-33 MPG on the Freeway.
Dennis |
vwfye Samba Member
Posted: Wed Apr 13, 2005 8:19 am Post subject: |
my FI in the 71 square is getting about 26 on the highway, but i can tell from the smells that i am running rich... so, 30 is probably possible. _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Posted: Wed Apr 13, 2005 1:55 pm Post subject: |
Well I dunno WTF then... _________________ OGST
Posted: Wed Apr 13, 2005 5:51 pm Post subject: |
Well I dunno WTF then... |
I get about 28-30 on mine as a daily driver. Ten miles of gravel, and 30 miles of open highway. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
negawsklov17 Samba Member
Joined: May 23, 2004 Posts: 95 Location: santa cruz and morgan hill
Posted: Wed Apr 13, 2005 6:32 pm Post subject: |
wow i wish mine was good. it's like 16 mpg if i'm lucky. mostly city streets. _________________ yup, i drive a porsche |
Posted: Wed Apr 13, 2005 6:54 pm Post subject: |
negawsklov17 wrote: |
wow i wish mine was good. it's like 16 mpg if i'm lucky. mostly city streets. |
Experience young Jedi. Experience. and practice. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Comandanteche Samba Member
Joined: November 18, 2003 Posts: 309 Location: Whittier, CA
Posted: Wed Apr 13, 2005 7:35 pm Post subject: |
youre getting 16 on carbs? is that normal? |
Posted: Wed Apr 13, 2005 8:09 pm Post subject: |
Comandanteche wrote: |
Not on a 1600cc stock engine. With 32 PDSIT's. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Wed Apr 13, 2005 8:53 pm Post subject: |
Russ Wolfe wrote: |
Not on a 1600cc stock engine. With 32 PDSIT's. |
No, it should be 21.5 or better. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
tomnotch Samba Member
Joined: October 22, 2004 Posts: 788 Location: Key Peninsula, Wash.
Posted: Thu Apr 14, 2005 5:01 am Post subject: |
I get around 27 out on the freeway. And I figure that may go up towards 3 after I do a couple of minor changes to my efi system. _________________ Tom
DVKK
DSD, Dark Side Disciples
Progenitor |
jaransonT3 Samba Member
Joined: January 01, 2005 Posts: 1262 Location: Dearborn, MI
Posted: Thu Apr 14, 2005 7:43 am Post subject: |
How much of an average is your 37mpg? If it is based ona single tank of gas or less it is pretty much meaningless, although it is high enough that it is likely you are lean.
Here is a chart I did of the mileage for my dual carbed 66 Squareback. I track it every tankfull.
Two things that really stick out. Temperature has a significant role in the mileage (at least with carbs...the FI might be better) as can be seen by the difference between the summer and winter months mileage.
The other thing is that there is a bunch of variation from tank to tank depending on where and how you drive, long trips vs. short, highway vs city, etc, etc. It is not uncommon to see 4-6 mpg difference from one tank to the next.
Make sure you have a few tank fulls run through the system with a variety of driving conditions before you jump to conclusions. _________________ Later,
John Jaranson
'66 Square
'69 Square
'70-1 Fasty
https://www.carartbyjohn.com
https://www.carartbyjohn.com/2024Invasion/ |
Posted: Thu Apr 14, 2005 10:59 am Post subject: |
well, i've been filling up the tank many times as i'm sure we all have, and on my FUEL INJECTED STOCK MOTOR i get 160 miles per tank maximum. it's really the pits, which is one of the reasons i'm planning to switch it over to dual 34 dell's with the help of my father.
and no you can't have my FI parts, sorry _________________ yup, i drive a porsche |
Posted: Thu Apr 14, 2005 11:23 am Post subject: |
and no you can't have my FI parts, sorry |
You should just fix the injection. Get a Bentley and check the resistance on the head temp sensor first. Then, adjust the mixture at the pressure sensor using a sniffer. Assuming that the basic settings are correct, it's probably just that simple. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
