orangabug Samba Member
Posted: Thu Apr 14, 2005 9:11 pm Post subject: air filter |
Pulled open the air filter cover in my new 68 sqbk and found that there was nothing there. What moden air filter would fit in there?
Maybe a FRAM part number or something that I can pick up at the local chain parts store. _________________ Real men wear ORANGE. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Apr 14, 2005 9:15 pm Post subject: |
A stock air filter is an OIl bath filter. Probably better than any paper one you can find. There should have been about 1/2 pint of oil in the air filter bottom. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Thu Apr 14, 2005 9:39 pm Post subject: |
To be exact, Russ, as I did this a couple of days ago, it should be 13.5 ounces _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Thu Apr 14, 2005 10:02 pm Post subject: |
So after I add some oil what type of filter should go in there. Do you have any pictures?
BTW: Orderd a Bentley manual and still waiting for it to arrive... so I have a few of the bonehead questions till then. _________________ Real men wear ORANGE. |
73notch Samba Member
Posted: Thu Apr 14, 2005 11:09 pm Post subject: |
no filter necessary. just oil _________________ SubyNotch.com is back up! |
seans67 Samba Member
Joined: October 06, 2004 Posts: 453 Location: End of the Road, Alaska
Posted: Thu Apr 14, 2005 11:13 pm Post subject: |
The stock air cleaner does not take any type of inserted filter, it is a self contained unit. The actual filter part of the unit is in the upper piece when you open the cleaner up.
Just drain the oil out of the bottom, clean the sludge if there is any and put 13.5oz SAE 30 oil in.
Put it back on the engine and your good to go. _________________ Sean
'71 Squareback '71 Porsche 914 ‘80 Camper '87 Syncro Weekender 1.8T '87 Wolfsburg Weekender '97 Toyota Land Cruiser ‘03 Audi A6 Quattro 3.0 ‘04 Audi A4 Avant Quattro 1.8T ‘05 Audi A4 Quattro 3.0
‘06 Porsche Cayenne Turbo S |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Fri Apr 15, 2005 3:03 am Post subject: |
orangabug wrote: |
BTW: Orderd a Bentley manual and still waiting for it to arrive... so I have a few of the bonehead questions till then. |
no paper - oil only...
believe it or not, the oil bath air filter is superior to any filter element you will ever stuff in there... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Fri Apr 15, 2005 7:32 am Post subject: |
You must have one of those Brazilian air cleaners from the kits sold back in the late 70's and early 80's. The closest filter I've found that fit's in there is from an 83 chevy cavalier 2.0 tbi (if I remember correctly). It's a little smaller in diameter, but it's the right height. I had one of those units in my wife's Fastback (it came with the car), and I searched all over trying to find one (with the VW and Audi part numbers). I never did find the correct one, but I did get close. Since then, I've found / got an oil bath filter, and stopped looking for them. Just so you know, K&N wasn't any help either. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Apr 15, 2005 7:57 am Post subject: |
Bobnotch wrote: |
You must have one of those Brazilian air cleaners from the kits sold back in the late 70's and early 80's. The closest filter I've found that fit's in there is from an 83 chevy cavalier 2.0 tbi (if I remember correctly). It's a little smaller in diameter, but it's the right height. I had one of those units in my wife's Fastback (it came with the car), and I searched all over trying to find one (with the VW and Audi part numbers). I never did find the correct one, but I did get close. Since then, I've found / got an oil bath filter, and stopped looking for them. Just so you know, K&N wasn't any help either. |
I have pictures of the paper filter style on my web site. Notchboy put them up I believe.
http://classicvw.org/gallery/notchboy
That is what the paper cartridge ones look like.
And also, even Mahle Filters is no help on getting the cartridges. BTDT I work for Mahle Filters. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
vweater1 Samba Member
Joined: January 08, 2004 Posts: 349 Location: LakeView Terrace, California
Posted: Fri Apr 15, 2005 11:05 am Post subject: |
How about if you have after market air filters, Could you use the oil bath air filter? I currently have 34ict's and would like to use the oil if possible. Or does anyone make some K&N style filter that could fit under the engine lid? |
Posted: Fri Apr 15, 2005 5:07 pm Post subject: |
After looking through a box of stuff that came with the car... I found a modern air filter that fit right in the there. Wonder if it was used? Wonder if it was used with or without oil? Would it have hurt anything? _________________ Real men wear ORANGE. |
Posted: Fri Apr 15, 2005 5:26 pm Post subject: |
Does the filter assembly look like the one on my web site??
http://classicvw.org/gallery/notchboy/1073066772437_MVC_010S
If it looks like that one? then put the cartridge in and run it. Be be forwarned, that you probably won't find another cartridge for it. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Fri Apr 15, 2005 10:28 pm Post subject: |
Quote: |
Does the filter assembly look like the one on my web site?? |
Nope. It has a orange trim and I can barely make out a part number that starts with PH. If I'm not mistaken, it looks like your run of the mill AutoZone/PepBoys/Kragen FRAM filter. _________________ Real men wear ORANGE. |
Posted: Sat Apr 16, 2005 5:48 am Post subject: |
orangabug wrote: |
Nope. It has a orange trim and I can barely make out a part number that starts with PH. If I'm not mistaken, it looks like your run of the mill AutoZone/PepBoys/Kragen FRAM filter. |
In this case, just install it and go (no oil needed). You might want to take it to one of those places you listed above, and see if they have another one in stock. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Apr 16, 2005 6:01 am Post subject: |
vweater1 wrote: |
If you're using ICTs, you're stuck with what you have, as the linkage would get in the way, along with having nothing for the wing nuts (on the oil bath air cleaner) to grab on to.
The choice of filters for them depends on the kits you have, as the CB Performance kits use a filter similar to a K&N, while the empi kit uses a paper element sealed to the tin halfs (the round ones anyway, and they appear to be a throw away type of setup). Some of the other empi knockoff's use a K&N style filter with the air cleaner cover plates clipped together, these are similar in style to the CB Performace elements, and can be cleaned or replaced. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
kirschwagen Samba Member
Joined: April 11, 2005 Posts: 113 Location: bristol, rhode island
Posted: Sat Apr 16, 2005 6:34 pm Post subject: air filter |
hey again orangabug.
checking the oil bath filter was the first thing i did on my square
back in the fall. it is quirky - but it's not that there's no filter in there.
look at the underside of the lid closely. see the holes with steel wool inside.
dude - that's the filter! genious engineering design!
so, fill the other half of the assembly with half a quart
of monograde hd30 if you have it lying around. i get mine
at napa or coastal. harley's use it. that should be your summer
weight oil too if you're going old school monograde heavy duty
oil like me. hd 20 in the winter.
so there you have it. oil. steel wool. best filter. just change
the oil and scoop out the sludge on the bottom every couple months.
oil bath - the original k&n filter charger = ) |
