Porsche wheels on type 3
Page: 1, 2, 3, 4, 5  Next
markstype3
markstype3 is offline
PostPosted: Thu Apr 21, 2005 11:56 am    Post subject: Porsche wheels on type 3 Reply with quote
Hi i have a 68 square. Will i be able to put on the 16x6 and 16x7 porsche fuchs on the car using the empi adapters? Any backspacing issues? thanks.
Mr. Bubblehead
El Chupa Nibre
Mr. Bubblehead is offline
PostPosted: Thu Apr 21, 2005 1:26 pm    Post subject: Reply with quote
Have you considered having the drums and rotors redrilled instead? It seems like that would cost less as well as avoid any spacing issues.
OGST
Samba Member #4862
bugginmiami
bugginmiami is offline
PostPosted: Wed Apr 27, 2005 1:40 pm    Post subject: Reply with quote
Wheels can fit, but ve only seen it without adapters, and it was close, id think with the adapters they wouldnt fit. I wouldnt run adapters given half a chance not to. Get em drilled.
jasonw
* ---www.volksblast.com--- *
* -- South Miami - Feb 12th 2017 *
johnnypan wrote:
Never mess with a cat who smiles for his mug shot..he gives way less of a fuck than you do..
R.Rabbit
R.Rabbit is offline
PostPosted: Wed Apr 27, 2005 6:55 pm    Post subject: Reply with quote
hey bubbles, nice pic in the avitar
and Porsche fuchs look terrible on a T3 IMO Wink
here's a 69 with 16x6 and 16x7
Opportunity may knock only once, but temptation eff' leans on the doorbell!
SBS #5
'54 RHD Swedish 3-fold
'60 L345 Doppelkabine
josh
josh is offline
PostPosted: Wed Apr 27, 2005 7:56 pm    Post subject: Reply with quote
I think the 914 2.0 Fuchs look pretty good on a type3 and the fit using the stock 4 bolt lug pattern.
FASTBACKDON
The other insensitive jerk like Neil
FASTBACKDON is offline
PostPosted: Thu Apr 28, 2005 11:16 am    Post subject: Reply with quote
I have 15x6 alloys all the way around drilled rotors 4 wheel disc fit great
kenikh
kenikh is offline
PostPosted: Tue Sep 26, 2006 10:14 pm    Post subject: Reply with quote
Old thread, I know, but if you could: what size tires on the sixes? Is this an IRS car?
>Kenik<
- 1971 Fastback Resto Hotrod
- 1969 Porsche 911S
"Now, to put a water-cooled engine in the rear and to have the radiator in the front, that's not very intelligent."
-Ferry Porsche
FASTBACKDON
PostPosted: Wed Sep 27, 2006 7:23 am    Post subject: Reply with quote
Alloys had 145's up front and 195/60/15's
the cookie cutters on my car now are 15x6's too 145's up front and 165's in the rear
kenikh
kenikh is offline
PostPosted: Wed Sep 27, 2006 7:26 am    Post subject: Reply with quote
Thanks!
>Kenik<
- 1969 Porsche 911S
-Ferry Porsche
rauschenbach
rauschenbach is offline
PostPosted: Tue Feb 19, 2013 12:18 am    Post subject: 15x6 Original Porsche 911 Fuchs Alloys Reply with quote
What do I need to do in order to get 15x6 Porsche Alloys fitted on my '65 Notchback Type 3?
View user's profile Send private message Visit poster's website Facebook Twitter Instagram Gallery Classifieds Feedback
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Tue Feb 19, 2013 3:48 am    Post subject: Re: 15x6 Original Porsche 911 Fuchs Alloys Reply with quote
several options:
adapters
drill existing drums for wheels
buy new drums, pre-drilled
póg mo thóin
Certified DHS Technician
Samba Member # 24517
rauschenbach
PostPosted: Tue Feb 19, 2013 3:20 pm    Post subject: Type 3 Options Reply with quote
Thanks. I called around to ISP West and Pierside Parts and looks like I can get a rear drum adapter from EMPI that converts wide 5 to small 5.
I don't want to do adapters for the front as my car is lowered and don't think I'll have any clearance for the wheels and it'll look funny. Looks like I can do Disc conversion to the front which will cost about $80/pair of spindles and $400 for the rotors, bearings, calipers and new master cylinder.
That is a pretty expensive option to get the Alloys fitted. I might just go with some replicas instead. Damn. I really wanted the real McCoy.
-Brian
Erik G
Erik G is offline
PostPosted: Tue Feb 19, 2013 4:21 pm    Post subject: Reply with quote
You don't need any of that nonsense to run them on the front. Just get front rotors redrilled. Any machine shop can go 4x130 to 5x130. You can buy them already done. No need for new spindles. You have the easiest vw to put Fuchs on period
Wait, you do have a stock 4 lug disc front beam, correct?
Bobnotch
Bobnotch is offline
PostPosted: Tue Feb 19, 2013 5:26 pm    Post subject: Reply with quote
I think he's on wide 5's, since he was looking at an adapter for the rear drums.
Rauschenbach, you do know all you need for the rear, is some 4 lug drums and hubs, that would need to be redrilled right? The rest of the parts are basically the same.
For the front, I'd shop around, and see IF I could get a set of spindles with the rotors still on them, or find a cheaper set of spindles. Same applies with the rest of the disc brake parts you're looking to buy. I only say that, as the rotors are the same as a type 1 Ghia, the re-pop calipers are too, as are the bearings. The master cylinder will be t-3 only, and you could find one in the classifieds, and send it to Jim Adney for rebuilding (or rebuild it yourself). Shop around, as you can cut the price down, since you're using mostly stock parts.
I only say that, as I've got about 600 into my wide 5 disc converion, and 500 of that was the disc kit. Shocked
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Erik G
Erik G is offline
PostPosted: Tue Feb 19, 2013 5:53 pm    Post subject: Reply with quote
I just don't realistically think there are many 5 lug 68's out there. Who would do all that work to go backwards. They do make 4lug vw to 5 lug Porsche adapters, which might actually work well in some applications to keep the wheel off the spring plate
If he does have wide 5 I'm willing to trade for my stock disc spindles. I have a whole 4 lug beam actually with new ball joints and bushings. Pm me
Bobnotch
Bobnotch is offline
PostPosted: Tue Feb 19, 2013 6:07 pm    Post subject: Reply with quote
The OP of this thread (started back in 2005) had a 68, but rauschenbach (who asked the question recently) has a 65 Notch.
Tram wrote:
Tram wrote:
Erik G
Erik G is offline
PostPosted: Tue Feb 19, 2013 6:18 pm    Post subject: Reply with quote
Forrest > trees Laughing
vlad01
vlad01 is offline
PostPosted: Tue Feb 19, 2013 6:29 pm    Post subject: Reply with quote
imho stock or fuchs are the only wheels that look good on a type 3.
wj32796
wj32796 is offline
PostPosted: Tue Feb 19, 2013 7:32 pm    Post subject: Reply with quote
Someone say Fuchs? Here's mine.
vlad01
vlad01 is offline
PostPosted: Tue Feb 19, 2013 7:39 pm    Post subject: Reply with quote
awesome, that looks wicked Twisted Evil
Page 1 of 5
