supaninja Samba Member
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Wed Feb 27, 2013 7:08 am Post subject: |
well each to their own.
must be a honduh thing? |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Wed Feb 27, 2013 8:29 am Post subject: |
supaninja wrote: |
being different is the theme of my notch build. |
I've always thought that of any type 3, since we're the "red headed step child" of the VW community. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
tim3 Samba Member
Joined: February 01, 2004 Posts: 547 Location: Los Angeles, CA
Posted: Sat Sep 07, 2013 10:46 am Post subject: |
can someone link me to the 5x130 rotors, and rear drums?? i cant find a vendor _________________ Click to view image |
tim3 Samba Member
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1165 Location: Las Vegas, Nevada
Posted: Sat Sep 07, 2013 12:26 pm Post subject: |
Yes. the front rotors are for the bug and type 3 are the same so they will fit your car.
The dics conversion for the rear of your car CB makes 4 bug kits, early bug shot axle one with a splined rotor, the other is shot axle with a hub and 914 rotor. They also make 2 long axle kit basically the same as the shot axle kit but it has a 16mm spacer for the long axle. You want the bug 67-68 long axle bug kit for your type 3.
The only issue you will have is making a bracket for the stock E-brake
cable retainer, easily made from a couple pieces of angle.
_________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
tim3 Samba Member
tim3 Samba Member
tim3 Samba Member
Posted: Sat Sep 07, 2013 7:37 pm Post subject: |
where can i find this???? i remember these being sold back in the day are these discontinued?
vlad01 Samba Member
Posted: Sun Sep 08, 2013 10:35 pm Post subject: |
Check with Mario at T3HQ. He is now having 5 x130 rear hubs made in Germany. Check his classifieds ads. |
vwsplitvan Samba Member
Posted: Fri Jan 23, 2015 6:45 pm Post subject: Wheel bolt size? |
I have an original set of 2 Litre Porsche alloys to run on my square.
What wheel bolts can I use? original Porsche 914 ones? Pitch/Size/Length?
Anyone have the spec required to run them safely?
thanks _________________ SBS #20 UK
RHD 62 Ragtop Beetle Beryl Green
LHD 69 Squareback Peru Green
LHD 63 Splitscreen Highroof Pearl White |
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Mon Jan 26, 2015 8:34 am Post subject: Re: Wheel bolt size? |
vwsplitvan wrote: |
thanks |
I ran my set of Mahle 914 rims on my Square before I went 5-lug. They fit perfect and fit exactly as the 2.0L Fuchs. Just use the longer wheel bolts made for the Fuchs and you'll be fine. If you run standard VW lug bolts you will only have about 3 threads holding everything in place.
I found the right set on eBay. Personally, I would highly recommend switching to studs and using lug nuts. Way easier to get a wheel on/off with studs and studs are much safer. The size is M14X1.5X45mm. Here's the studs I am using: p/n: 904 341 671 00. Hope this helps!! _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Jan 26, 2015 8:56 am Post subject: |
I ordered these longer Mercedes style lug bolts from ezaccessory for my OG 2.0 liter wheels. I have to run EMPI spacers on the rear to get the dust caps to fit on all the way. A bonus is that the spacers set my 205X70 tires just right from the rear fenders! http://www.ezaccessory.com/Lug_Wheel_Bolts_s/20.htm _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
vwfye Samba Member
Posted: Mon Jan 26, 2015 9:57 am Post subject: |
The 4 lug Mahle wheels fit nicely, but if you 205s under the rear, use spacers or you will rub on the spring plate of a swingaxle car.
I wish I still had mine. Doh! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Posted: Mon Jan 26, 2015 10:56 am Post subject: |
Cheers I have ordered some M14 x 1.5 x 27mm thread, radius seat, for now until I can find some original quality bolts.
Thanks for the info. _________________ SBS #20 UK
Posted: Wed Jan 28, 2015 10:15 am Post subject: |
Aftermarket bolts arrived but are crap and too short.
So on the lookout for the genuine Porsche 914 bolts if anyone has some they can help out with.
See What you mean about the rear center caps not fitting all the way Mike.
I think spacers will put my tyre against the fender arch lip. What other options are there? Other than not running the cap.
Anyone making slightly bigger caps to take the castle nut?
On a 71 IRS squareback
Posted: Wed Jan 28, 2015 10:58 am Post subject: |
I told you mine fit with spacers & you then decide they won't fit without even trying! I used the 39 or 45mm lug bolts. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Wed Jan 28, 2015 11:02 am Post subject: |
Mike my wheels fit and I only have a finger gap between the tyre wall and the fender arch. What size spacer have you used? my car is a 71 IRS model.
185/65R15 tyre on the 5 1/2 J 914 Alloy wheel.
I am down 1 outer on rear and 2 outer on front.
What size spacer? _________________ SBS #20 UK
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Wed Jan 28, 2015 11:22 am Post subject: |
vwsplitvan wrote: |
What size spacer? |
stack some washers to see how much you'll need to fit the cap. Pr can you clearance some stuff to make it fit? _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
