Tvättbjörn Samba Member
Posted: Tue Apr 26, 2005 10:42 pm Post subject: WCM window seals / which molding |
I´m replacing my squareback side window seals. Had no problem with the pop out windows. But with the rear side windows I´m having big time trouble to install the molding. I got told that these seals are made for the aluminium molding. Does anybody know if that is correct??? |
Kenaneu Samba Member
Joined: March 20, 2005 Posts: 156 Location: San Francisco, CA
Posted: Wed Apr 27, 2005 2:05 am Post subject: |
The trick is to put in the moulding BEFORE You reinstall the windows... Otherwise it's going to bend, dent and generally be impossible to install. |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Wed Apr 27, 2005 3:39 pm Post subject: |
If there is a groove in the outer face of the seal, you got the right one.
It took me 2 hours/window to do what you're doing, and I had the wife to help. (That may have been the problem. ) _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Wed Apr 27, 2005 6:17 pm Post subject: |
Thanks for the note. Proberly you are right, since I have only two hands and the other two out of town for a while, I will put them in the sun first and use tons of lube to do the job. Any special lube I should use??? |
Posted: Wed Apr 27, 2005 7:24 pm Post subject: |
soap works well for me, and washes off easily afterward. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Apr 27, 2005 7:32 pm Post subject: |
I use GoJo hand cleaner without the pumis. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Wed Apr 27, 2005 7:53 pm Post subject: |
I've used Zmol rubber dressing, soap and silicone lube. All worked well. I've heard recently that liquid soaps may contain salt wich could lead to corrosion of the body and aluminum. I don't know if it's true but I stopped using it. |
