73resto Samba Member
Joined: August 11, 2003 Posts: 669 Location: Durham, CT
Posted: Mon May 02, 2005 5:44 pm Post subject: New fender |
I want to paint my new fender.
do i have to sand the shipping paint off down to bare metall or can i scuff it and then prime it??
I was told i could scuff it but i don't know what that paint is or if it will hold other paints |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue May 03, 2005 8:34 am Post subject: |
If it's that thin black crap, remove it. |
bmtx Samba Member
Joined: December 28, 2004 Posts: 606 Location: The Lone Star State
Posted: Tue May 03, 2005 10:09 am Post subject: |
It doesn't nessicarly have to be removed. Its a corrosion primer that can be painted over. You could sand it with 320da, get the imperfections out, scuff it with a scotchbrite pad and paint it. Most paint and body shops would go this way. If you want a show quality job, remove it, etch, prime, ect. |
Slowlow Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Tue May 03, 2005 6:10 pm Post subject: |
BMTX is right, I own a body shop and that would be our exact method. _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
Posted: Sun May 08, 2005 1:36 pm Post subject: |
thanks.
I have 3 fenders like that and one of those 4 new ones is covered in red primer. is that primer selfetching primer? .
so if i do d.a. it ( the black fender) and scuff it , i just need to spray it with my high build primer surfacer and forget the self etching primer . or do i need to put that down also. |
happy hoppy Samba Member
Posted: Mon May 09, 2005 7:04 am Post subject: |
if you don't know what it is, get rid of it!
it might come back to bite you! _________________ cut, hammer, weld, drive.
not necessarily in that order. |
bmtx Samba Member
Posted: Tue May 10, 2005 11:56 am Post subject: |
You can spray the primer over it without the etch. The etch is for bare metal substrates. |
Posted: Thu May 12, 2005 7:00 am Post subject: |
There is small surfice rust under the black factory paint coat. So i will be taking all the fenders down to bare metal. And bodoing the small dings. Then i will selfetch prime everything. Will this primer pick up the bondo or not stick to the bondo? |
bmtx Samba Member
Posted: Thu May 12, 2005 9:34 am Post subject: |
Its okay to spray the etch over filler. |
Posted: Thu May 12, 2005 9:44 am Post subject: |
Wash primer should be kept away from fillers to the extent reasonably possible. Epoxy primer may be applied either over or under fillers. Surfacer goes over the top of the fillers and is sanded. Sealer, not always used, goes over the surfacer immediately prior to application of the finish coats.
You need to treat that rust with metal ready, picklex or something else before you bodywork over it.
This is all off the PPG data sheets, that is the only line of products I am familar with.
All you folks who were telling 73resto not to worry about leaving the crap primer on there, now you can see why it needs to come off. You're relying on the workers in the mexican or brazilan factory to have stored the raw sheetmetal and finished product in proper conditions to prevent the formation of micro rust prior to application of their primer. How good do you think that Mexican primer is? Considering how much a decent paint job costs to redo, I think a couple hours with a DA and a rotary brush getting most of that primer off would be a no-brainer. |
