Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed May 04, 2005 9:34 pm Post subject: Speaking of the "Price of wiring" |
Well, my front clip for the Ghia should be here in a few days, and I get to rip the wiring out of the front of the Ghia so the cuts can be made.
Well, rip probably is not the proper term. More like disconnect and pull the harness back and strip the dash.
The cuts will probably be made on the windshield posts and the rocker panel near the heater outlets.
This will be my first front clip replace. Anything I should watch for?? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Wed May 04, 2005 9:46 pm Post subject: |
Measure twice, cut once. _________________ OGST
Samba Member #4862 |
BryanM Samba Member
Joined: June 14, 2002 Posts: 4212 Location: Concord/Charlotte NC
Posted: Wed May 04, 2005 10:10 pm Post subject: |
Mr. Bubblehead wrote: |
Measure twice, cut once. |
more like measure 5 times, cut large and trim untill it fits. _________________ -Bryan
Motorwagen LLC
Concord NC |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Wed May 04, 2005 10:11 pm Post subject: |
Take your time! and measure more than twice. Your harness runs through the rocker right? Pull it back as far as you can and wrap it in some protecetive materail. How are you going to weld the A-pillar, if you butt weld, have a windsheild around to double check the opening size. Depending on how you weld up the rockers it should line up pretty easy, but hang a door before you weld, to line up your reveals. I know you'll be O.K. on the mechincals. If any of the wires run though the panels you are replacing, run some type of wire so you can grab on to them later . hope this helps , I know i'm missing some more things, but take your time. Cut down to size, fit it in, cut down to size, fit it in, repeat, Weld once. _________________ It's not about the window, it's about the people.
German Folks |
tomnotch Samba Member
Joined: October 22, 2004 Posts: 788 Location: Key Peninsula, Wash.
Posted: Thu May 05, 2005 7:00 am Post subject: |
cut as squarely as possible.
over-trimming is a no-no.
he who welds well, should weld this. _________________ Tom
DVKK
DSD, Dark Side Disciples
Progenitor |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu May 05, 2005 9:43 am Post subject: |
BryanM wrote: |
more like measure 5 times, cut large and trim untill it fits. |
Love it. Can I quote you on that?
- Scott _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Thu May 05, 2005 4:27 pm Post subject: |
I think I am going to pay a professional to make the cuts. A good friend of mine is a body man, and he said he would do it for me. I have to pull the windshield and the doors off too.
I do have the big Bentley manual, and it gives all the dimensions for the windshield open and the door openings.
I might make a template before I make the cuts. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Thu May 05, 2005 5:08 pm Post subject: |
By the looks of the clip, it looks like you won't be butt welding the A-pillar. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Thu May 05, 2005 5:38 pm Post subject: |
The side marker looks good have you figured out how to run the defrost tubes? _________________ It's not about the window, it's about the people.
German Folks |
Posted: Thu May 05, 2005 5:49 pm Post subject: |
Not yet, I need to get them side by side. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Fri May 06, 2005 7:22 am Post subject: |
Russ Wolfe wrote: |
I might make a template before I make the cuts. |
Templates sound like a good idea. Make sure it's square before welding, and use any and all existing bolt holes available to help align it. To do the defrost / heater tubes, you'll have to open the rocker up to weld them, so you might want to do this after it's located so you can hide the cuts and welds under the carpet (BTDT). Sounds like you'll be busy for a few days with this. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
