Bagged 65 beetle
Page: Previous  1, 2, 3  Next
KantDriveFast
KantDriveFast is offline
PostPosted: Mon May 23, 2005 7:32 pm    Post subject: Reply with quote
But this way, I wont have to worry about destroying any exhaust system I put on it.
BE CAREFUL! When that bad boy hits bottom, it won't destroy the exhaust...It'll beat up the rear apron first! Otherwise, for a first timer...you are doing an exceptional job! Awesome Car!
bpoogas
bpoogas is offline
PostPosted: Tue May 24, 2005 8:16 am    Post subject: Reply with quote
This is my first car, so it goes a little slow, I have to ask questions about every single thing ! I have been reading all the VW mags since I was 16, So I know what my bug should "look like". Now I've had to learn how to make it look like that.
I think even with it low, the muffler tips are under the apron, so I think they would go first. But I don't have to worry about any of that, I just hold the switch for 2 seconds and it goes up to stock height! it's awesome.
I got the front finished last night, but I need smaller tires bad. The pan is still 2 inches off the ground cause the front fenders sit on the 165 tires. Since I'm desparate to be low I'm going straight to the 135 everyone has. Smaller tires would get me lower from the fender and also from the ground with the low profile.
I still need to hook up the steering wheel, pedals, shifter, gas tank, and put my white Procar seats in. I will get pics this week.
View user's profile Send private message Visit poster's website AIM Address MSN Messenger Gallery Classifieds Feedback
bpoogas
bpoogas is offline
PostPosted: Mon May 30, 2005 12:19 pm    Post subject: Reply with quote
Took it outside for the first time in 3 months. (One month was just
waiting for a tranny, and a couple weeks waiting for some Spindles).
Let me tell you it's a little scary driving while sitting on a cinder block.
Seats will be installed as soon as possible. I have some white Scat Procar
seats to go in (mounted a couple inches back from stock pos.)
Since everything was taken apart and replaced, the need for alighnment causes a very scary driving experience.
So now It's just down to all the small details. (trim, handles, tail lights, small tires, etc.)
Airkewld
Airkewld is offline
PostPosted: Tue May 31, 2005 6:25 am    Post subject: Reply with quote
Cinder block racing seats? Whooaaa! Be safe first and the kewl will come later! Take care Brad! Good job!
TheSamba members-only discount - Samba24
Win a FREE Chassis Rebuild - https://airkewld.co/WinAChassis
Learn from a PRO on Patreon - https://www.patreon.com/Airkewld
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba
bpoogas
bpoogas is offline
PostPosted: Tue May 31, 2005 12:03 pm    Post subject: Reply with quote
Laughing The block was originally there so my girl could pump the brakes while i did the brake bleeding. It was either that or a Lawn chair. (now thats big pimpin) Cool I did put a towel on it for padding. I only drove it about 50 yards from my house anyway. It still needs to be aligned before I do anything else.
I will put the seats in this week.
The cinderblock did work better than the bucket I used a couple months ago.
Picture this, Everything seems ok until... Throttle gets stuck on full power, shifter knob comes off in my hand, and my bucket is falling over when I turn!
I thought I was going to die! (despite going maybe 10 mph). That was the test drive of the old tranny before I took the body off and redid the pan. At least the brakes worked. ha ha.
I Hope nobody follows my bad example of safety. Thanks for the tip!
bpoogas
bpoogas is offline
PostPosted: Thu Jun 02, 2005 10:26 pm    Post subject: Reply with quote
Got the 135's. Should I get 145's for the back? Or stay with the 165's?
We will see. It's still got a while to go before it's "done".
low66
low66 is offline
PostPosted: Thu Jun 02, 2005 10:58 pm    Post subject: Reply with quote
looks good go with 145's in the back for sure
Pennywise
Pennywise is offline
PostPosted: Fri Jun 03, 2005 5:51 am    Post subject: Reply with quote
I would definitely not go with the 145s in the back. Leave the 165s on.
Slowlow Premium Member
Slowlow is offline
PostPosted: Fri Jun 03, 2005 7:25 am    Post subject: Reply with quote
Seeing as its bagged, keep the 165's in rear. I would only worry about the 145's if it were just slammed.
• Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 •
Slowlow is offline
Slick looking car too, by the way..
I need a shoe horn
I need a shoe horn is offline
PostPosted: Fri Jun 03, 2005 7:57 am    Post subject: Reply with quote
That is really nice looking Cool I'm trying to get parts together for my 65 vert here in reno I was wondering how hard it was to install the air ride im looking at getting the airkewld kit.
bpoogas
bpoogas is offline
PostPosted: Fri Jun 03, 2005 9:51 am    Post subject: Reply with quote
Maybe 145's in the rear for "shows" and 165s for driving. I dunno.
For "I need a shoe horn", I think the Airkewld kit is probably on of the best ways to go as for Ease of instalation, and simplicity.
You will probably need the layed back shock tower extensions for a 65. I have regular extensions and they poke into the trunk a little bit. I wouldn't want to cut into a vert body. The back is a little harder since you have to weld in the upper bag mounts.
I need a shoe horn
PostPosted: Fri Jun 03, 2005 11:14 am    Post subject: Reply with quote
Thanks for the info im not looking to lay pan just a smooth ride and drop it low when parked. Do you have to use those extensions on the front?
bpoogas
bpoogas is offline
PostPosted: Fri Jun 03, 2005 11:49 am    Post subject: Reply with quote
This is the LOWEST the front would go, without the extenders and 165 tires.
You don't want to drive it at the bottom of the travel, so you will basically have to raise it up to stock height just to drive it. And remember I still have dropped spindles on.
I dont think anybody should run the airshocks without the extensions even if it's just for ride quality. Maybe shorter airshocks will become available in the future. Up travel was also limited since the shock is too close to the beam in the stock position. The extensions have multiple maounting positions for fine tuning the low point and give a lot better movement of your trailing arms.
70fasty
ITMC Member
70fasty is offline
PostPosted: Sat Jun 04, 2005 3:09 pm    Post subject: Reply with quote
nice car, i just picked the same color for my fastback, hopefully it will turn out nice Very Happy
And is it a hard job at all installing the air ride? i might get a kit for my fasty when i save up some money from working this fastback is my first car and im 17 got mine when i was 16 too
WRX Blue 1970 VW Fastback
ITMC
bpoogas
bpoogas is offline
PostPosted: Thu Jun 23, 2005 8:39 am    Post subject: Reply with quote
I got the whole car polished this week and put the trim back on.
Also bolted up the Scat procar Elite seats. I welded some 1.5" angle pieces
to mount them to. 4" back compared to stock position for more legroom.
The new hubcaps make it look more finished. Also hooked up the taillights with new lenses.
Airkewld
Airkewld is offline
PostPosted: Thu Jun 23, 2005 9:31 am    Post subject: Reply with quote
Brad, it looks one of a kind! Great job!
Slowlow is offline
PostPosted: Thu Jun 23, 2005 2:39 pm    Post subject: Reply with quote
Man, that thing looks awesome. I really like all the white and the white-walls. Killer!
bpoogas
bpoogas is offline
PostPosted: Mon Jul 04, 2005 4:34 pm    Post subject: Reply with quote
Still recovering from Friday/Saturday/Sunday night here in Vegas.. ha ha...
I have a boring monday afternoon to waste. Here's the wheels I've been
looking at for some time now. Thinking about a white powdercoat?? Is it possible to powdercoat alloy? Maybe I'll get them sprayed.
Before I get the discs and wheels, I'll need to get a good Alarm and other
Anti-theft devices, Does anybody know what alarms are good for VW's?
I want to get the best one that is compatable.
Slowlow is offline
PostPosted: Tue Jul 05, 2005 4:52 pm    Post subject: Reply with quote
I would answer your question but Im too busy drooling over the porsche wheels on that thing....
Might just be a photoshop, but that would look killer.
Page 2 of 3
