StRkLyGeRmAn15 Samba Member
Joined: July 05, 2004 Posts: 116 Location: san bernardino so cal
Posted: Sat May 07, 2005 11:13 am Post subject: wiring harness |
ok guys..i think im just gonna start fresh..but i need to kno first if there are complete wiring harnesses for my 69 square with CARBS..if not..do they have em with fuel injection and how hard is it to take it out..were can i find one..thnx Jim |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat May 07, 2005 11:23 am Post subject: |
There are new wire harnesses available, but they are expensive. They are a lot of work to build, and a lot of work to put in.
And then, you still have to sort it all out. My suggestion is to find someone in your area, that is familiar with VW wiring and pay them to straighten it out. If there are no burned up wires in the main harness, the old one can be repaired.
Everything si color coded in a VW wire harness. It is just like a paint by numbers set. Follow the colors and do it 1 at a time. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
fastback1971 Samba Drummer
Joined: January 02, 2005 Posts: 239 Location: Tri-Cities
Posted: Sat May 07, 2005 11:34 am Post subject: |
I said this before and got some snotty replies, but Watsons street works sells a very well engineered G.M. style harness. Its great and comes with a full set of schematics. I have personally installed one and will on every V.W. I own in the future. The wires are all high temp. and it comes with everything(except tools) including ends and fuzes. But its about $350. There are lots of open fuze positions also for future mods. If you want a factory look I cant help. I would take Russes advice. Try and locate some original wire and prepare to pay. Either way, you cant go wrong by replacing 36 year old wiring. Good luck. _________________ I refuse to tiptoe through life, only to arrive safely at death. |
Posted: Sat May 07, 2005 11:55 am Post subject: |
fast back..is it easy to put in..is it very self explanotory..my harness unde rthe dash is so messed..and some wires are painted.. |
Grant Samba Member
so wiring works isn't doing type-3s? the T-2 ones are sweet and only like $175 i think. |
Posted: Sat May 07, 2005 2:47 pm Post subject: |
I found it very easy. But it is universal meaning, not type specific, so you'll need a good wiring diagram. I also have electrical experience. i dont want you to get in over your head. Pay attention to the schematic and follow the diagrams, you'll do fine. If you run into problems take pictures, post them here, there are some really good guys and girls on here to help.You might need a friend for some of the jobs. I would say the hardest part will be getting the bundle through the fender area. Anyone have any advice to make this easier? The good thing about the harness from Watsons is its marked every couple inches, so you dont have to mark every wire. Top quality. _________________ I refuse to tiptoe through life, only to arrive safely at death. |
Posted: Sat May 07, 2005 3:40 pm Post subject: |
Proper way to get the harness through the rear fender is to pull the fender. I can take a picture of the one that is still in my parts car. The fender is off the car. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Sat May 07, 2005 6:39 pm Post subject: |
ISP West has a really nice complete wiring harness or you can get a main harness from WCM or CIP. _________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
Posted: Sat May 07, 2005 7:27 pm Post subject: |
thanks so much man..that isp west WAS EXACTLY wat i needed thank u very much |
PIMPPRIDE Samba Member
Joined: November 19, 2003 Posts: 879 Location: Carson California
Posted: Sat May 07, 2005 10:14 pm Post subject: |
yes we have the complete harness instock.. headlight to tail light... |
