Pacmanfever Samba Member
Posted: Thu May 15, 2014 9:24 pm Post subject: |
Today I installed the wingnut hardware, I'm holding off on the latch hardware until the seals are sorted out. The wingnut hardware fit very well with just a little adjustment for alignment, right now it's screwed in place, but we'll weld it as we prep the interior for paint.
Unfortunately steaming the seals with the espresso machine didn't change anything other than making the kitchen humid as hell. I also hung them in the sun for the whole day, tomorrow I'll take a shot at gluing them in as placeholders for another set.
Here is a close-up of one of the seals with the deformity from folding during shipping, normally I'd hope these crushed areas would resolve with time and some direct sun, but this material is so stiff, it won't stay in the frame. Its hard like an old garden hose, I may end up with plain weatherstrip until some good seals arrive since rain is forecast early next week.
On the upside, driving with the Safaris open is awesome! We went out for ice cream this evening and they were perfectly stable even at highway speeds.
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Fri May 16, 2014 1:21 pm Post subject: |
Since you are probably going to replace them anyway, have you considered throwing them in the dryer with a load of rags to see if that has any effect? It would heat them up evenly. Maybe worth a shot. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Sat May 17, 2014 8:26 pm Post subject: |
cru62 wrote: |
Since you are probably going to replace them anyway, have you considered throwing them in the dryer with a load of rags to see if that has any effect? It would heat them up evenly. Maybe worth a shot. |
That's a good idea, I did something similar with boat rub rail by soaking it in a bathtub of super hot water before installation. The only way to get these to stay was to glue them in, so they'll stay until something else arrives.
Today we drove an hour up to Volksweston, the Mo Kan VW Club show in Weston, MO and the seals worked reasonably keeping the wind noise down, but there are small gaps wherever there is an irregularly from the way they were packed. |
nigel naughton Samba Member
Posted: Mon May 19, 2014 10:18 pm Post subject: |
I just wonder why is is SOOOOO hard for them to make this stuff the way it is supposed to be made??? With today's tech you would think that it would be easy enough to reproduce at least as good as factory. Makes me frustrated to say the least. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue May 20, 2014 6:55 pm Post subject: |
nigel naughton wrote: |
Hi five slap and parallel thoughts to that. |
surveylifer Samba Member
Joined: September 23, 2012 Posts: 7 Location: Evergreen CO
Posted: Tue May 20, 2014 7:06 pm Post subject: Seals |
http://www.mcmaster.com/#bulb-seals/=s1z741
Ive been reading about the seal problem and read about the ones from buttysbits and found them on mcmaster carr site for half the price and recieved them in 3 days and the fit amazing. Even on the radius' no bunching
I ordered two 10' pieces for about $55. I know not cheap but what is if it works.
On a different note do all bus's have notches at the top of the window to recieve the safari hinge. I have a 67 13 window. Any one with knowedge let me know |
Posted: Tue May 20, 2014 7:10 pm Post subject: Seals cont |
Addl it is adjustable edge grip seals #7 on th mcmaster site |
grey60 Samba Member
Posted: Tue May 20, 2014 10:11 pm Post subject: Re: Seals cont |
surveylifer wrote: |
Part number is 12335A44.
On a different note do all bus's have notches at the top of the window to recieve the safari hinge |
Anyone have a pic of the notches?
Pretty certain my 1960 commercial panel doesn't have them.
I am having trouble visualizing how the threaded plates pacmanfever made should fit into the body…
Slipped inside under the roof on either side of the vent intake?
So it's: Screws through window hinge --> drilled holes in body --> threaded plate? _________________ 1960 grey panel |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Tue May 20, 2014 10:41 pm Post subject: Re: Seals cont |
grey60 wrote: |
So it's: Screws through window hinge --> drilled holes in body --> threaded plate? |
Early bus did not come with the notches that started in the mid 60's something i think around '63/'64-ish
Can't remeber off hand if earrly ones with factory safari had them or not
Yes the thread plate goes inside the body you have to punch a hole in the windshield frame and slide them in to the other side window _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Tue May 20, 2014 10:47 pm Post subject: |
Yeah, the indent was a later thing. If you want some fun, search 'early vs late safaris' and read the debate.
Was that in this thread? |
grey60 Samba Member
Posted: Wed May 21, 2014 12:23 am Post subject: |
Z wrote: |
If you want some fun, search 'early vs late safaris' and read the debate. |
Dear god. Just kill me now.
Well it can't be nearly as bad as the 'What oil shall I use' discussion. _________________ 1960 grey panel |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Wed May 21, 2014 6:48 am Post subject: |
grey60 wrote: |
Z wrote: |
Well it can't be nearly as bad as the 'What oil shall I use' discussion. |
Yeah, that thread has gotten pretty out of control! _________________ -Adam
'59 Mango Bus - getting buried in it
'69 Bug - sold and highly missed, so it stays in the sig |
cru62 Samba Member
Posted: Wed May 21, 2014 7:31 am Post subject: Re: Seals cont |
joe56vw wrote: |
grey60 wrote: |
Yes the thread plate goes inside the body you have to punch a hole in the windshield frame and slide them in to the other side window |
On he last bus I installed those plates in I didn't punch two holes like the service bulletin instructs. I cut one hole on the upper DS opening just big enough for the plate with a stiff wire attached. I taped the wire to right end of the DS plate, installed it in the PS header and then pulled it back to the DS. Then I installed the PS plate. It is a good idea to leave the wire attached until you have the center screw installed and the plate is not able to move all over the header. AMHIK _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Posted: Wed May 21, 2014 8:05 am Post subject: Re: Seals cont |
Here are the vintage Safari instructions for VW dealers: http://www.vintagebus.com/howto/safari.html
And here is a helpful thread with clear pictures: http://www.thesamba.com/vw/forum/viewtopic.php?t=189195
Some have pop riveted them in without using the threaded plate, but you lose the adjustability the floating threaded plate provides. It is more work to put the plate in, but it allows you to compensate for the seals after they take a "set", and ease of removal in the future which in our case is soon as we're slowly getting ready for paint. |
Ohio_Style Samba Member
Joined: July 09, 2007 Posts: 610 Location: You'll never leave Sparta alive, Ohio
DerekR Samba Member
Joined: July 22, 2004 Posts: 384 Location: Riverton, Utah
Posted: Fri Jun 20, 2014 7:00 am Post subject: |
I ordered my EIS safari's and had them at my door in Utah in 3 days. The fit is good, no complaints. _________________ 63 Ruby Red Double Cab
60 SO 23 Westfalia SWR/BG Camper
59 Dove Blue Standard Kombi |
cru62 Samba Member
Posted: Fri Jun 20, 2014 7:49 am Post subject: |
Ohio_Style wrote: |
I decided to finally bust open the piggy bank for safaris, it sounds like EIS is the way to go, anyone who thinks I should buy wolfgang's instead?
Also, I'm needing them sorta fast, who has the better leadtime? |
While it appears that EIS has some of the same issues that the WG safaris do, they a have gone the extra mile and made them as close to original as any other brand on the market. I imagine that you would have much less chance of glass breakage with EIS as opposed to WG. The fact that the frame pieces will actually interchange with original is HUGE! _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
ritchiet002 Samba Member
Joined: January 27, 2003 Posts: 1676 Location: Kaneohe, HI
Posted: Wed Jul 16, 2014 8:21 pm Post subject: |
what's the difference between a 55 to 63 rear bus safaris and the ones sold for the 55 to 65, single cabs and double cabs, besides costing $200 more? _________________ Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________ |
Z Samba Member
Posted: Wed Jul 16, 2014 8:43 pm Post subject: |
ritchiet002 wrote: |
what's the difference between a 55 to 63 rear bus safaris and the ones sold for the 55 to 65, single cabs and double cabs, besides costing $200 more? |
Trucks have a different shaped rear window. The safaris have a different hinge setup, too, I think. |
Posted: Wed Jul 16, 2014 8:49 pm Post subject: |
that's right! The window is the same as a barndoor. I'd get more for my money with front safaris. _________________ Somewhere there is a jar with your name on it!
