The Noof Samba Member
Big Dave Samba Member
Posted: Sun May 15, 2005 7:57 pm Post subject: |
Lookin' good
Is your car fuel injected or are those carbs? |
Posted: Sun May 15, 2005 7:58 pm Post subject: |
Blow through weber turbo. |
mattsvdub Samba Member
Joined: September 12, 2004 Posts: 366 Location: Goodrich Michigan
Posted: Sun May 15, 2005 8:06 pm Post subject: |
Hey Noof, What year is that? 71 - 72 ?
One of the nicest late model T-1's I've seen...
Is that a CB Turbo setup or did you piece it together yourself?
Do you have the motor specs listed somewhere here on Samba...
Nice work... |
Posted: Sun May 15, 2005 8:10 pm Post subject: |
Thanks bro...it's a '72.The turbo is a kit from CB performance. I built most of the car myself. There's more jpegs in the gallery. |
gospeedgo1 Samba Member
Joined: September 02, 2004 Posts: 70 Location: modesto,ca
Posted: Sun May 15, 2005 8:30 pm Post subject: |
it looks beautiful. hey, why do you have the cheap plastic fuel filter in the engine bay? fire is a risk. i like the set up. hows the turbo set up run? what type of turbo is it? t3/t4? _________________ Since when do decals add horsepower?! |
Posted: Sun May 15, 2005 8:34 pm Post subject: |
Those aren't the shitty filters that you think.I have one on each carb, as well as an EFI filter before the pump inlet.The turbo is a Schwitzer t3. As for the performance...it flies. |
67sleeper Samba Member
Joined: April 19, 2004 Posts: 62 Location: uncharted desert isle
Posted: Sun May 15, 2005 8:42 pm Post subject: |
dude, your bug is clean! I like... thanks for the pics |
Posted: Sun May 15, 2005 8:49 pm Post subject: |
The Noof wrote: |
I thought webers sucked (no pun intended) for a blow through setup. Did the kit include the carbs? Looks like a trick setup. |
Posted: Sun May 15, 2005 9:06 pm Post subject: |
Big Dave wrote: |
The Noof wrote: |
I love the setup. I did 1 jet change and it's been perfect. Pump the gas twice cold, and it idles lumpy right away. 30 seconds later, it idles perfect. Gas mileage is very good, performance is excellent |
Posted: Sun May 15, 2005 9:09 pm Post subject: |
The only kits on their website I see are FI setups. I wonder if i could build a setup around my 44IDFs? |
danimal Banned
Posted: Sun May 15, 2005 9:50 pm Post subject: |
the vwdoctor did blow-thru with stock webers, i think that they come with solid floats and a rubber gasket on top... but i'm not a weber guy so check it for yourself, i've only run dells.
nice job noofimal!!! looks like a real clean install. _________________ ... |
bk63rag Samba Member
Joined: February 26, 2004 Posts: 883 Location: Martinez ,ca
Posted: Sun May 15, 2005 11:36 pm Post subject: |
Nice car it looks like it means buiseness _________________ 63 rag under construction for 30 years and counting. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
