73resto Samba Member
Joined: August 11, 2003 Posts: 669 Location: Durham, CT
Posted: Wed May 18, 2005 7:51 pm Post subject: Hows my booth? |
ideas? suggestions? |
BIG MAC Samba Member
Joined: August 28, 2003 Posts: 105 Location: Hemet, Ca
Posted: Wed May 18, 2005 11:52 pm Post subject: |
You better make sure you have plenty of room to move around on all sides. From the pics it looks a little tight. Also make sure you have plenty of ventilation. That tent will fill up with overspray real fast, and could cause problems later. |
theotherone Samba Member
Joined: November 20, 2004 Posts: 188 Location: sitting on top of the world (duh duh duh da da duh duh duh..)
Posted: Thu May 19, 2005 6:43 am Post subject: |
looks kewl, but i dont have ant experience with these things. I am planning to do something similar only mine has to be out doors because my garage is so small, as far as ventilation are you using the tshirt over the fan trick???
does that actually work i hear the shirt will catch the spray as the fan pushes the air out of your tent......
good luck i am interested in how this works for you because i will be doing similar work in a few weeks! _________________ rollin in the teeks with a 70 standard/ 69 bay/ and soon a 64 standard! |
happy hoppy Samba Member
Posted: Thu May 19, 2005 7:22 am Post subject: |
I have done the same many times, works fine!
I would "ground" the car to prevent static , helps keep dust off the paint.
I use jumper cables, ground the pan and the body to a water pipe. _________________ cut, hammer, weld, drive.
not necessarily in that order. |
justBugging Samba Member
Posted: Thu May 19, 2005 7:58 am Post subject: |
My brother made an inflatable booth for a friend that blows up anywhere. He makes inflatable jumps just like the one in the picture. Basically, he made 4 inflatable columns. one opens up with velcro. The walls are made with vinyl similar to the one he uses for the jumpers. Instead of putting a jumping bed, he just put a tarp under to protect the floor from getting any paint. he also made one of the walls with the ventilation holes for 2 vacuums.
I'll ask my brother to take some pictures so I can post here. but I think it's an awesome idea!
Regards,
Mark |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Thu May 19, 2005 8:03 am Post subject: |
i think you should put the exhaust fan on an opposite wall of the intake filters...you want to suckout the overspray...with your setup, you might just circulate the overspray a little while the air being sucked in makes a U-turn and goes right back out....also, makes sure you have plenty of lights...i really like the shade canopy on the top...smart thinking... _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO
dude!!!
how much and how much to ship to manteca ca????? _________________ rollin in the teeks with a 70 standard/ 69 bay/ and soon a 64 standard! |
Posted: Thu May 19, 2005 8:21 am Post subject: |
I'll ask him. We are in So. Cali so I don't think it would be that much for shipping. |
Posted: Thu May 19, 2005 8:27 am Post subject: |
justBugging wrote: |
depending on where you are i might be able to drive down and pick it up.
depends on the cost of the booth and shipping _________________ rollin in the teeks with a 70 standard/ 69 bay/ and soon a 64 standard! |
Posted: Thu May 19, 2005 8:38 am Post subject: |
He said he can make you a 13'x23' big enough for a Chevrolet Caprice station wagon, this includes the blower to blow it up and everything you need to operate the unit. The price is $1500.00 with Free shipping to Manteca CA. He will deliver the inflatable booth out to your door.
If you need an air extractor, he can provide it for an additional $300.00 or you can buy one from any paint supply. He will leave the pipe for the extractor.
If you need special dimensions to reduce the cost, please let me know.
One of the many advantages about this booth is portability. You can roll it up and take it anywhere. It will blow up in 2 min and roll it down takes 5 min. |
bmtx Samba Member
Joined: December 28, 2004 Posts: 606 Location: The Lone Star State
Posted: Thu May 19, 2005 8:54 am Post subject: |
I think it would be awesome to have a Finding Nemo paint booth . You could open the market up wide with that stuff. |
4ghias Samba Member
Joined: May 16, 2004 Posts: 331 Location: Calif. Sacramento Area
Posted: Thu May 19, 2005 8:56 pm Post subject: |
With my luck there would be a power failure and the whole thing would drop onto my new wet paint job. _________________ 4ghias |
4ghias Samba Member
Posted: Thu May 19, 2005 9:15 pm Post subject: |
Good Idea with the enclosure within the garage, I’m guessing that your putting the air compressor way out side and as Mark said (lots of light) hang a couple of cheap florescent lights for plenty of light. Looks like your pulling air from the top on one side and pushing it out on the bottom from the other? I think you would need more then one access for the air I would go all along the top on the opposite side of the fan. I would also get that real cheap painters clear drop cloth and line the inside so you can rip it off and toss between paint jobs to keep the main enclosure clean. _________________ 4ghias |
Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Posted: Fri May 20, 2005 5:01 am Post subject: |
also find a way to tie off the walls so they don't flap into your wet paint
maybe a small hole in the center of each wall with a string tied off to the walls inside.
also if you put in an exhaust fan, duct it (with something) out of the garage or the house will stink of auto paint for weeks
and use a respirator!! _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot. |
Posted: Fri May 20, 2005 8:50 pm Post subject: Primed 'em |
Well i did it .
I primed the fenders with 3 coats of self etching primer.
I got the runs in some places
but not bad for my first paint job.
I need to prime it with my buildable primer. Should i sand down the runs in the selfetching primer. can you even sand the etching primer???? |
bmtx Samba Member
Posted: Fri May 20, 2005 9:19 pm Post subject: |
Yes, you need to get the runs out of it. Yes, you can sand it. It will need to be sanded to give the highbuild primer something to stick to. |
Posted: Sat May 21, 2005 7:17 pm Post subject: |
Posted: Sat May 21, 2005 7:18 pm Post subject: |
i sanded the run like you said and primed them with the buildable prime. i think 3-4 coated . Whats the limit???with coats |
Posted: Sun May 22, 2005 11:39 pm Post subject: |
looks great, i am on my way to getting to where you are... keep the pics comin!! _________________ rollin in the teeks with a 70 standard/ 69 bay/ and soon a 64 standard! |
Posted: Mon May 23, 2005 7:34 am Post subject: |
3-4 coats of high-build is about maxed out...you will want to sand it down substantially...from everything i've come across, it sounds like you want to try and keep your etch and high build primer's total build as thin as possible... _________________ Wish List:
Mark Laken
Fort Collins, CO |
