arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3081 Location: The PNW, where "going green" means rolling with moss.
Posted: Thu May 26, 2005 5:07 pm Post subject: |
Cool booth! I just used plastic dropcloths, but it came out great:
[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=208926[/img]
Another tip is to get the floor wet, so any dust will stick to it instead of getting kicked up on your paint. _________________
cdennisg wrote: |
Lawyers don't deserve buses. |
zozo wrote: |
Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
Posted: Thu May 26, 2005 5:15 pm Post subject: |
Crap, let me try that again. . .
[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=208926[/img] _________________
cdennisg wrote: |
zozo wrote: |
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
Posted: Thu May 26, 2005 5:29 pm Post subject: |
3rd times' a charm!
cdennisg wrote: |
zozo wrote: |
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
wheel607 Samba Member
Posted: Thu May 26, 2005 6:02 pm Post subject: |
Three coats of high build primer? High build is nothing more than thin body filler but you should only use one coat to cover the small imperfections still showing through your etch primer. Three coats and I will guarantee in six months to a year or sooner you will have spider viening under your new paint. This stuff is meant to be sanded off almost entirely only leaving small scratches filled |
theotherone Samba Member
Joined: November 20, 2004 Posts: 188 Location: sitting on top of the world (duh duh duh da da duh duh duh..)
Posted: Thu May 26, 2005 10:32 pm Post subject: |
arthurnugen wrote: |
3rd times' a charm!
looks sweet... did you paint the inside also????
did you use one of those resin or epoxy based primers??
looks great!!!!!!!!!!!!!!! _________________ rollin in the teeks with a 70 standard/ 69 bay/ and soon a 64 standard! |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Fri May 27, 2005 6:12 am Post subject: |
wheel607 wrote: |
3 wet coats before sanding is what all the high build primers i've seen explain in their instructions...obviousouly you would sand it down substantially...but 1 coat would give you very little to sand, no?...
depending on what's being talked about, there are lots of 2k or epoxy high build primers that are a little more than thin body filler...they promote bonding (Primer aspect) and they don't absorb moisture like filler does... _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Posted: Fri May 27, 2005 8:45 am Post subject: |
Thanks! 2 coats of Dupont self etching primer, then wet sand, primer in spots, wet sand, etc! The color is a Dupont Centari single stage acrylic. I am in the process of color sanding it now. _________________
cdennisg wrote: |
zozo wrote: |
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
Posted: Fri May 27, 2005 8:49 am Post subject: |
I did the inside too:
I didn't do the whole interior down to the floor (no one will see it with carpet anyway) but the rest of it came out awesome! I had to weld in a donor piece where the radio block off plate is, as someone had a hacked out a big hole to put in some monster stereo. _________________
cdennisg wrote: |
zozo wrote: |
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
Naked Samba Member
Joined: August 03, 2004 Posts: 568 Location: Lincoln, Ca
Posted: Fri May 27, 2005 9:09 am Post subject: |
Ok here is my $0.02. Some of the newer technology primers out there are not good to wet sand. Wet sanding is old out of date process. Its bad emviromentally (im not jumping on some band wagen). Wet sanding some primers, will cause the primer to case harden after the water dries. All you would need to do is go back and give it a light scuff with some red or grey scotch brite, if not your paint will not stick. Check with the paint store and ask for a "P" sheet on the material. I paint cars on a daily basis I havent used water to sand a car in over 10 years, primer or clear. My experience with metal etch is you put on 1 light to medium wet coat and let flash 10-15 minutes. Then apply you primer/sealer. I usually wouldnt put more than 3 coats of primer on at a time. If I know Im gonna reprime something because of body work. I prime it, block it out with 80-120g then 180. Reprime, block with 180g, 240g and finish it with 320-400g. The primer we use right now is R/M Dp200 a very high build primer. If you get too much on it will spit and crack with in 2 days. This goes with any part of paint or body work, dont try to do it all in one step. Put body filler on 2 or 3 times. Prime it twice. Clear twice if you have too. Taking extra steps only makes your work come out better. I used to work for a guy that would say. "We dont have time to do it right, but we have time to re-do it" _________________
68' Vert
