rich53x Samba Member
Joined: November 02, 2004 Posts: 94 Location: North East, MD
Posted: Wed May 25, 2005 5:16 am Post subject: What is "wet sanding" and how do you do it? |
I think I know what wet sanding means, but not sure if there's a particular way to do it when you're working with metal. |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Wed May 25, 2005 8:56 am Post subject: what is wet sanding how do I do |
Don't wet sand bare metal , only paint or primer . TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Wed May 25, 2005 11:51 am Post subject: Dumb question: What is "wet sanding" and how do yo |
Thanks, I didn't even know that much. - Can you tell me a little more though about wet sanding? |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Wed May 25, 2005 12:36 pm Post subject: |
wet sanding is ussually done with finer grit sandpapers (400, 600, 800, 1200, 2000 grits), water and a hand sanding block (not a DA sander or jitterbug sander to the best of my knowledge)...the water helps keep the paper from cloging up...you can either put a constant stream of water on the area you are sanding (i take a 2 Quart plastic juice bottle and put a small slice in the bottom of it...then set it above the area i'm working and let gravity deliver the water)...this way ultimately leaves a big puddle of dirty water somewhere but it is easier on your skin...
the other way, which is what i normally do is to have a bucket close by half full of water and periodically dunk the sanding block in the water and swish it around and then return it to your work area sopping wet and sand for a minute or so...your hands will become pruney after a couple hours of this...i use an oven cleaning glove on my sanding hand when i think of it...
you do not really get different results by using wet sanding compared to dry sanding...it's just that the fine grit sandpapers clog easily and you make alot of dust with the dry sanding method...
my most preferred method is to use the yellow sand paper of 320 grit for prepping surfaces for paint and use it dry (autozone sells it..think it's called automotive paper? made by 3m?...use a mask/respirator to avoid dust in your lungs)...it doesn't clog like the black papers...you simply smack the sanding block a couple times and it is good to go for a couple minutes...i think its cleaner and quicker than wet sanding with 400 and should be good for pre-primer prep... _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Posted: Wed May 25, 2005 1:27 pm Post subject: |
Great information! I'm gonna check my local autozone for the 3m paper. It sounds like the way to go. |
Posted: Wed May 25, 2005 1:44 pm Post subject: |
while you are ther, buy a can of grease and wax remover...wipe on wipe off ala karate kid style before you start sanding, otherwise you can work grease into the surface as you are sanding...do this with wet or dry sanding... _________________ Wish List:
Mark Laken
Fort Collins, CO |
diy570 Samba Member
Joined: September 19, 2003 Posts: 1062 Location: Maggie Valley, NC
Posted: Wed May 25, 2005 2:00 pm Post subject: |
if you are blocking out primer, go dry and you will actually be able to see what you are doing and wont make a total mess. |
73resto Samba Member
Joined: August 11, 2003 Posts: 669 Location: Durham, CT
Posted: Wed May 25, 2005 6:55 pm Post subject: |
let the wet sand paper sit in water for atleast 30 minutes prior to sanding |
calbug65 Samba Member
Joined: September 11, 2004 Posts: 113 Location: Esco,Socal
Posted: Wed May 25, 2005 7:10 pm Post subject: |
Go in 1 motion front to back
sand till you cant see the marks from the grit you used before
so all the scratchs are gone..
if you realy have a nice body you can get 3800,4000,8000,12000 grit..
Peace Troy _________________ 65 Bug In The Works
1Pc Front,AirKewld Disc Brakes,CB Narrowbeam/Tierods(Powtercoated)
1835cc(Powdercoated Doghouse/Tins)
041heads,110Cam,Dellrado 34's,
A1 Sidewinder,Compufire DIS-IX Ignition,BMDSerpBelt,95Amp Alt
Custom Sound System & Interior/Dash |
Mr. Bungle Samba Member
Joined: December 11, 2003 Posts: 1705 Location: Vancouver BC, Canada
Posted: Wed May 25, 2005 11:42 pm Post subject: |
pale, warm water, a little dish soap, 600 - 1200 -2000 sand paper (let it soak in the water for a bit), a fexible sanding block (rubber) and crosshatch strokes. dip in the bucket every few minutes. never sand in straight lines and change directions every so often so you dont get "wear" patterns. _________________ Silas
Zundfolge Car Club
Stock Motor Challenge website |
