jps1145 Samba Member
Joined: March 16, 2005 Posts: 654 Location: Tehachapi, CA
Posted: Thu Jun 09, 2005 8:53 am Post subject: Tips on replacing seat track? |
My '66 is under construction and the pan is in pretty good shape except for the seat tracks. I've seen plenty of replacement pan sections that have the seat tracks, but I only need the track itself. Does anyone have a source for those? I'm also looking for tips for replacing them. Is there anything tricky about popping the old ones off and welding the new ones back in?
Thanks,
-John _________________ Tehachapi, CA
'69 Baja
Vintage Funco single seater
My Baja |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Thu Jun 09, 2005 10:29 am Post subject: |
no, just find the spotwelds, drill them out and plug weld the tracks onto your existing pan.
If it were my project, i would tack one side, install the seat and THEN tack the other side. double check the tracks for parallelism before fully welding them up or the seat will bind. |
Posted: Thu Jun 09, 2005 11:40 am Post subject: |
Now there is a $.25 word!
Thanks a bunch for the tip. I didn't think of setting the seat in place. I would have just used a tape, but the seat may bey a little out of parallel as well... _________________ Tehachapi, CA
'69 Baja
My Baja |
ekimthemad Samba Member
Posted: Fri Jun 10, 2005 2:31 pm Post subject: |
I just did this a couple months ago. If you can find a set of original tracks out of a donor. I made the mistake of buying replacement tracks. I had to cut the tracks in half because they were about half an inch to narrow. The top lip was also to wide and wouldn't allow the seat to clear the latch mechanism. The teeth on the latch mechanism were also to wide and had to be modified. I think that was all I had to do to modify them to get them to work!
Mike
59 single, 66 bug, 69 bus, 73 super
Member of the Ddk _________________ Remember never argue with a moron. They'll drag you down to their level and beat you with a lifetime's worth of experince. |
Posted: Fri Jun 10, 2005 3:02 pm Post subject: |
If the seat frame rails aren't parellel then you'll have to bend them straight. They have to be parallel or the seat won't move right.
Thanks for the compliment on the word. I take Paypal. |
