Radio grille cloth / radio installation / radio bracket
npbusguy
npbusguy is offline
PostPosted: Sun Jul 01, 2012 7:23 pm    Post subject: Reply with quote
That is very sexy. I don't remember seeing too many black knob radios.
PostPosted: Sun Jul 01, 2012 10:38 pm    Post subject: Reply with quote
Thank you.
Yes, the black knob radios are uncommon.
On this one the buttons are just painted though, not cast.
It is an original though, I did not paint them.
The tuning knobs are cast.
On a very similar topic, if anyone has an original Bus Sapphire rear mounting bracket, I would like to see the shape so I can replicate it... or buy it - I'd like to add one.
kguarnotta
kguarnotta is offline
PostPosted: Mon Jul 02, 2012 5:55 am    Post subject: Reply with quote
Nice work Everett.
I'll check to see about that bracket. Are you talking about the piece of steel that is sort of twisted in an odd manner, that attaches to the threaded bolt int he back of the radio, and through a bolt that holds the dash tray?
I know I've got one around my shop. If I get to cleaning this week-I'll let you know.
-Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper
twinwindows
Samba Pimp
twinwindows is offline
PostPosted: Mon Jul 02, 2012 7:46 am    Post subject: Reply with quote
I put this in my Deluxe but I`d like to find the OG stuff.
CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote:
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed.
PostPosted: Mon Jul 02, 2012 9:05 am    Post subject: Reply with quote
Yes, something like the "7C" bracket seen in this photo
This is from the Sapphire III installation booklet
I'm not sure which one was used for a Sapphire I but it may look something like the one 2nd from the right here, but with different bends:
The one 2nd from the right is for a Beetle.
The others I am not sure of, other than the one 2nd from the left and the one on the far right are Sapphire mounting brackets.
npbusguy
npbusguy is offline
PostPosted: Mon Jul 02, 2012 9:18 am    Post subject: Reply with quote
The one on my bus is similar to the second from the right, but the bends are a bit different.
A photo of it can seen in my gallery on page 8, but I can't post a link from my phone.
PostPosted: Mon Jul 02, 2012 9:28 am    Post subject: Reply with quote
Thanks, I found this photo
npbusguy
npbusguy is offline
PostPosted: Mon Jul 02, 2012 9:42 am    Post subject: Reply with quote
That is the one, hope it helps.
PostPosted: Mon Jul 02, 2012 9:51 am    Post subject: Reply with quote
Yes, it does.
I thought it went straight up and bent over to mount to the radio stud from the left side so that helps.
BarryL Premium Member
BarryL is offline
PostPosted: Mon Jul 02, 2012 7:05 pm    Post subject: Reply with quote
Here's mine. The dog-eared end goes on the parcel tray mid fastener.
PostPosted: Mon Jul 02, 2012 11:51 pm    Post subject: Reply with quote
Thanks, the measurements really helped me tweak the bracket I had been twisting around to try and get it to fit.
Bracket made with an aluminum piece from the hardware store:
If I can't find a real one in a reasonable time frame, I will duplicate it in steel - the aluminum is flimsy.
BulliBill
BulliBill is offline
PostPosted: Wed Jul 09, 2014 8:10 am    Post subject: Reply with quote
Wow, no action on this thread for a few years now...
Can anyone describe how the speaker cloth is attached or glued in place to the backside of the dashboard (before the radio and speaker is installed)? Do you use some sort of adhesive? Or does the install of the radio and speaker grill themselves hold the speaker cloth in place without any adhesive? Has anyone found the perfect material to use for the speaker cloth itself? The photo of the silver mosquito or screen door screen above are a bit too "see-thru", so I wonder if an suitable dark or black mesh material has been discovered. Sources? Availability?
Thanks!
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
PostPosted: Wed Jul 09, 2014 9:13 am    Post subject: Reply with quote
I can't speak to finding something better as I was happy with what I did above.
Nothing has deteriorated over the past 2 years but the top right corner came unglued and has dropped a little.
I may re-glued that at some point.
As far as I know it wasn't glued in place originally, I think the material was so stiff or was sprayed with starch, as mentioned earlier, to keep it formed to the dash?
Not totally related to the installation but for my own install I replaced my painted black knob radio tuner knobs with some cast black ones I found.
I also found an original rear speaker bracket, identical to the one BarryL posted above.
As far as I know it's common for there to be no rear bracket in place on Bus radios. Or installers left them off - it's kind of a pain to install, although maybe not if you do them all the time.
BulliBill
PostPosted: Wed Jul 09, 2014 9:34 am    Post subject: Reply with quote
Thanks for the reply Everett.
I think I'll want to use an adhesive to hold the screen in place top and bottom. What did you end up using? I'm thinking of cleaning the surface under the dash with wax and grease remover, then a bead of 3M weatherstrip adhesive top and bottom, then lay in and press the screen into the adhesive beads, and cross my fingers that it will hold forever! I have some close-mesh charcoal color mosquito screen, and I might mist it a little with aerosol black satin paint before install. Should help fill the pores and maybe stiffen it up more.
Bill
PostPosted: Wed Jul 09, 2014 9:57 am    Post subject: Reply with quote
I just put a tiny dab of Goop in the upper and lower right corners.
Probably not enough or the under-dash area was dirty.
I just quickly wiped it down before pressing it up in there. Lazy me.
Big Bill
Big Bill is offline
PostPosted: Wed Jul 09, 2014 3:35 pm    Post subject: Reply with quote
I wish I had seen this thread a week or so ago. Didnt know that the mesh should cover the radio itself, looks way better as seen in dubstars before and after photos. Not too bad of a job to pull the radio and speaker again and do it right.
*EDIT* I went back to my Gallery photos and looked again, not only did I not cover the radio I also put the mesh material on the back side of the speaker bracket. Duh!
PostPosted: Wed Jul 09, 2014 11:19 pm    Post subject: Reply with quote
From another thread
Pacmanfever wrote:
If you are looking for some heavy black screen material, Lowe's has "Pet Resistant" screen which is a nice heavy black mesh that should stay in place without adding starch or glue. I just used some on a screen door and it's very sturdy stuff.
glasspint
glasspint is offline
PostPosted: Thu Jul 10, 2014 6:15 am    Post subject: grill cloth Reply with quote
http://www.ebay.com/itm/Guitar-Amp-amplifier-PA-SP...?ssPageNam
PostPosted: Thu Jul 10, 2014 8:54 am    Post subject: Reply with quote
I thought of using some speak cloth as it was mentioned here so I went to the Salvation Army store to pick up a cheap speaker to steal it from but it seemed too thin to me.
Maybe the online stuff is thicker?
dubstar
dubstar is offline
PostPosted: Thu Jul 10, 2014 8:22 pm    Post subject: Reply with quote
I think it depends on the speaker; look for ones from the 50s and early 60s for thicker cloth...
1963 Type II Kombi
1977 Type I Fuel Injection
http://instagram.com/john_aka_dubstar/
http://web.stagram.com/n/john_aka_dubstar/
"you could transport really tall things too, like a giraffe"
Page 3 of 6
