golfmasterii Samba Member
Posted: Wed Jun 15, 2005 12:42 am Post subject: motor stops, red light comes on |
recently while driving my 1964 Notch my red light came on and the motor quit momentarily then started running again. Nothing else turned off, just the motor. Is this a coil problem? It's done it three times over about 100 miles driving but always starts running again within seconds. HMMMMMM??? I've checked out the wiring and it all seems fine, fuses are good, no burning electrical smell. _________________ Going Notchless is not an option |
Aussie Greg Samba Member
Joined: March 19, 2004 Posts: 253 Location: Blue Mountains N.S.W. Australia
Posted: Wed Jun 15, 2005 4:51 am Post subject: |
Just the basics I'd be checking your fuel filter is'nt clogged, check fuel lines for leaks, check your points and spark plugs and make sure you're ignition leads are all fitted tight and have'nt come loose. Does'nt really sound like its anything major wrong. Have you done any work on the notch recently before this problem started? Really makes me think its an intermittent fuel starvation problem. _________________ If it's not in a Volkswagen I'm not going!
My email - [email protected]
1963 Beetle
1965 Beetle
1982 Type 25 Transporter/Vanagon
1985 Type 25 Caravelle/Vanagon
2001 Golf |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Jun 15, 2005 11:04 am Post subject: |
Loose connection somewhere- at the starter, generator, or voltage regulator most likely. Could also be an ign. switch issue, but that usually affects other components as well. I'd track it down sooner rather than later. You don't want a live wire coming off something, grounding, and turning the wiring harness into a giant lightbulb filament! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Jun 15, 2005 12:07 pm Post subject: motor stops, red light comes on |
I replaced all fuel lines and filters approx 1000 miles ago. Just did a recent tune up 500 miles ago. Checked all connections except the starter, guess I will go there next. It will run fine for hours and then all of a sudden it dies. _________________ Going Notchless is not an option |
urchin Samba Member
Posted: Wed Jun 15, 2005 12:15 pm Post subject: red light |
I have had coils on cars act like that when they heat up runs fine for hours then shuts off then starts back up after a very short time. |
67FastyRSA Samba Member
Joined: September 28, 2004 Posts: 179 Location: Presov, Slovak Republic
Posted: Thu Jun 16, 2005 2:16 am Post subject: |
Loose fuse contact on the main fuse maybe? The "ceramic" fuses that they sell us these days are very poor quality and is made from plastic which gets shorter with some heat... maybe worth a check... |
