Kevin S. Samba Member
Joined: May 23, 2005 Posts: 113 Location: Vancouver, Washington
Posted: Wed Jun 15, 2005 8:24 pm Post subject: Fuel pump?? |
When changeing from a fuel injection set up to a dual carb. Can I still utalize the same fuel pump?? Or do I need to go to a mechanical????? Is the fuel injection pump to much?? Or will still work?? _________________ Do you feel lucky???? |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Jun 15, 2005 9:02 pm Post subject: |
The FI pump is way too much. You will need to convert to the mechanical pump that the stock carbs use.
BTW, I will buy the FI parts. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Wed Jun 15, 2005 9:05 pm Post subject: |
The only things I have from the Fi is the regulator and the main computer. My fasty didnt come with a motor. I wish it did. I would use the Fi with the 1776 that I am going to install. Can I use a aftermarket electric fuel pump?? Or would the recomendation still be for the mechanical?? _________________ Do you feel lucky???? |
Posted: Wed Jun 15, 2005 9:35 pm Post subject: |
I just removed the fuel tank and it does still have the fuel pump. If that intrests you. Not sure if it works. Going to remove it and hit it with some power and see if it comes to life. _________________ Do you feel lucky???? |
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Wed Jun 15, 2005 9:51 pm Post subject: |
I will take any and all fuel injection parts that you are removing from your vehicle. _________________ OGST
Samba Member #4862 |
Posted: Wed Jun 15, 2005 10:06 pm Post subject: |
Maybe we can trade for some stuff I need????? I am always up for a goor trade.... i just found some old tin rings. The ones that were held on by the center caps. In pretty good shape. I just gave them a good cleaning. Nice and shiny. Good for anything but a frisbee???? _________________ Do you feel lucky???? |
Posted: Thu Jun 16, 2005 9:07 am Post subject: |
Kevin S. wrote: |
I just removed the fuel tank and it does still have the fuel pump. If that intrests you. Not sure if it works. Going to remove it and hit it with some power and see if it comes to life. |
And I spoke first Mr. B.
Yeah, I am interested in what ever you have. I need to get the Ford pump off mine before Tram finds out. Also, the FI wire harness should still be there if they just pulled the engine.
Dont run the pump very long with it dry. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Jun 16, 2005 9:12 am Post subject: |
Russ Wolfe wrote: |
Kevin S. wrote: |
Dont run the pump very long with it dry. |
You thought I didn't KNOW??? BWAAAAAHAHAHA! The next knock on your door will be KGB.... _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Jun 16, 2005 9:28 am Post subject: |
Yes I have the computer and the harness. I dont need it. I will box it, the regulator, the pump and whoever wants it can have it. I am trying to gently remove the fuel pump wireing too. Do you guys want that in the box too. Give me a address and it is yours. If not I was going to give it to the DDB. I need a backseat cushion. Maybe worth a trade??? _________________ Do you feel lucky???? |
Posted: Thu Jun 16, 2005 9:33 am Post subject: |
Back seat cushion?? Fastback or Squareback? I might have one, but no promise. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Thu Jun 16, 2005 9:48 am Post subject: |
It is a 1971 fasty. it doesnt have to be new. I would just like pretty good shape. _________________ Do you feel lucky???? |
Posted: Thu Jun 16, 2005 11:09 am Post subject: |
Hmmmm, Maybe I should start parting out my '71 Fasty now. Nahhhhh, It may be in bad shape, but it gets me there, and gets me back.
Sorry, I only have a spare Squareback seat cushion. Actually, with shipping, it would be better to find one local. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Thu Jun 16, 2005 11:10 am Post subject: |
Russ Wolfe wrote: |
Sorry, I only have a spare Squareback seat cushion. Actually, with shipping, it would be better to find one local. |
I'll take the fuel injection- wrong pump and all! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Jun 16, 2005 12:05 pm Post subject: |
Russ you still want the fuel injection stuff that I have??? I got you address that you sent me. If so. I will box it and ship on the 25th. Just let me know. Either way. _________________ Do you feel lucky???? |
