oil-breather valve part number
islandwesty
islandwesty is offline
PostPosted: Sun Jun 19, 2005 3:17 pm    Post subject: oil-breather valve part number Reply with quote
I would like to replace my old worn out oil breather valve, pvc valve, whatever you want to call it. Part number is 071 115 327. This number is not showing on any parts source search engines... has it been superceded by another part number? Will another unit from a different engine work? This is for Vanagon type-4. If anyone knows the low-down on this matter, I would be most appreciative..... Very Happy
'80 VW Westfalia
'90 Ford Aerostar E4WD
'94 Ford Escort Wagon
Prejudice is an emotional commitment to ignorance.
Karl
Karl is offline
PostPosted: Sun Jun 19, 2005 3:40 pm    Post subject: Reply with quote
It has been superceded to part # 030 115 327A
The only dealer I could find listing it in inventory is:
SPEEDCRAFT VOLKSWAGEN
WAKEFIELD,RI 800-782-3189
You may be able to order it from your local dealer.
islandwesty
PostPosted: Sun Jun 19, 2005 3:48 pm    Post subject: Reply with quote
alright! can you post a searchable link for VW dealer parts? not been there yet.
'80 VW Westfalia
islandwesty
PostPosted: Mon Jun 20, 2005 4:00 pm    Post subject: Reply with quote
Rolling Eyes been informed by nearest VW dealer (Speedway in Victoria) that this part is NLA by VW. Am I getting the runaround? I am thinking of trying another dealer, as it has been in my experience that some dealers are more air-cooled friendly than others....
What are some alternatives to this part if I can't find? What are some things people have done to replace this part?
'80 VW Westfalia
Randy in Maine
Randy in Maine is offline
PostPosted: Mon Jun 20, 2005 5:38 pm    Post subject: Reply with quote
If your dealer won't do it for you, I would call up that dealer in RI and have them send it to you.
islandwesty
PostPosted: Tue Jun 21, 2005 9:56 am    Post subject: Reply with quote
....so, I "bothered" four more VW dealers in a radius search, and one had the courtesy to inform me what Karl already did (thanks Karl!):
"The 071115327 was ss'd by the 030115327A in 1986 ,but then the 030115327A was discontinued in 1999. There is one dealer in the states that show one still in stock, and you would have to contact them directly.
www.speedcraftvw.com"
Upon phoning them this morning: "I show ZERO in stock" Rolling Eyes bummer. (Maybe someone beat me to it, unless mistake in inventory)
Does anyone out there know if these valves are "serviceable"? Looks like they aren't, but I'd be willing to try. Any valves from different engine compatible?
'80 VW Westfalia
mightyart
mightyart is offline
PostPosted: Tue Jun 21, 2005 10:13 am    Post subject: Reply with quote
You don't need it, but the breather can't be plugged, just make sure it doesn't leak air. The round one way valve isn't needed
see here's mine:
My Art:
http://www.gordonflynn.com
islandwesty
PostPosted: Tue Jun 21, 2005 10:19 am    Post subject: Reply with quote
MA, so you're just running a pipe straight from the case to your intake boot? Any concerns about excess oil consumption? Thanks.
'80 VW Westfalia
mightyart
PostPosted: Tue Jun 21, 2005 10:25 am    Post subject: Reply with quote
Doesn't work that way. Wink its just a sort of vent for the engine, you do get a small amount of oil, but it is very small and happens over a long time, so it really is unnoticable.
My Art:
islandwesty
PostPosted: Tue Jun 21, 2005 11:05 am    Post subject: Reply with quote
Ummm, fighting... base... impulse.... spray.... Gum-out.... in the breather valve... Argghhh!!!
Dumb idea? Like you said, the valve is probably fine, I know it's not clogged as I am getting oil (little) sucked into the throttle body (probably what's been rotting my intake boot). I have had PCV valves replaced on numerous cars I've had in the past, and I thought it would be a good idea to try and track one down, but seeing as that is impossible, I need to work with what I have. I will definitely replace the o-ring that seals the valve to the case, mine's hardened up. Know an on-line vendor that pushes one?
Thanks.
'80 VW Westfalia
cobmojo
cobmojo is offline
PostPosted: Sat Oct 22, 2011 10:05 am    Post subject: Reply with quote
Does anyone know where (a website, dealership, ect) that has the Oil Breather Valve (PVC breather valve) for an air-cooled vanagon?
Please! I've looked everywhere and can't find one.
This place is out of stock: http://www.germansupply.com/home/customer/product.php?productid=16820&cat=348&page=8
p.s.
Is there even an option for cleaning it? Has anyone ever done that before?
Wildthings
Wildthings is offline
PostPosted: Sat Oct 22, 2011 11:47 am    Post subject: Reply with quote
p.s.
How many threads are you going to post this same question in? Must be 4 or 5 at this point when one would have been plenty.
newport5
newport5 is offline
PostPosted: Wed Jun 05, 2013 9:18 am    Post subject: Vanagon breather Reply with quote
Hello Vanagon owners,
I came across a new breather, 030 115 327 A. It's still in the parts bag. I'd love to sell it at a fair price. VictorB at NewportMotorsports.net
