Don't know my greases?
amishman
amishman is offline
PostPosted: Fri Jul 08, 2005 7:35 pm    Post subject: Don't know my greases? Reply with quote
I purchased and used some Pennzoil 705 Multi-Purpose White Grease for when I did the shift rod bushing fix a while back. Made that shift rod push right thru. Probably good for prostate checks also Shocked
Anyway, is this same grease OK to use on my brake drum when I re-insert bearings back into the drum? Or, is it a different kind used for that purpose?
The stuf I have says it is NLGI #2 Water Resistant grease.
Thanks for answering a newbie question. I always see grease things up but never sure what exact greases I should use.
tj
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jul 08, 2005 7:45 pm    Post subject: Reply with quote
White grease is OK for the asjusting screws and where the shoes contact the bscking plate.
But you should use a good synthetic "wheel bearing" grease (usually blue) on the wheel bearings.
Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
radioman
radioman is offline
PostPosted: Fri Jul 08, 2005 8:21 pm    Post subject: Reply with quote
What Glenn said! Cool
It's a Southern Thing, 73, stock.
Bill
