66fasty Samba Member
Joined: June 23, 2004 Posts: 193 Location: Banning,ca
Posted: Wed Jul 13, 2005 7:17 pm Post subject: Stock rims on Lowered Car |
Is it possible to use Stock rims on a lowered car?I'm "trading" my Porsche 2liter repo rims with 195/65's for some engine parts to rebuild my Engine.I have a set of stock rims and a set of 8 spokes.I would prefer to run the stock rims over 8 spokes.I'm not sure how many clicks my car is lowered,but the front beam is 2 1/2-3in off the ground,I'd say the rear is lowered 2 clicks.What size tires can be run?I'd like to have some decent contact patch on the fron,but I'm not sure if its possible.
P.S. I *DID* search.
Thanks,
Philip |
FASTBACKDON The other insensitive jerk like Neil
Joined: October 08, 2004 Posts: 3592 Location: TORRANCE CALIF
Posted: Wed Jul 13, 2005 7:21 pm Post subject: |
sure it is possible i did it 20 years ago on my 1st fastback a 67 3 notches in the front 2 in the rear untill i could afford 8 spokes |
Posted: Wed Jul 13, 2005 7:23 pm Post subject: |
on my 67 i used 135/15's in the front 165/15's in the rear |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Wed Jul 13, 2005 7:50 pm Post subject: |
I've got stock rims and 165R15 tires on my '71 square that is lowered. I'm not sure how far since the PO did it. They rub when you have it turned about 80%. Here's a pic of the front:
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
jaransonT3 Samba Member
Joined: January 01, 2005 Posts: 1262 Location: Dearborn, MI
Posted: Wed Jul 13, 2005 8:06 pm Post subject: Re: Stock rims on Lowered Car |
66fasty wrote: |
Thanks,
Philip |
You will be far better off with the stock rims than the 8-spokes on a lowered car. The offset of the 8-spokes hurts you since it is set up for a Beetle, not the Type 3. _________________ Later,
John Jaranson
'66 Square
'69 Square
'70-1 Fasty
https://www.carartbyjohn.com
https://www.carartbyjohn.com/2024Invasion/ |
Posted: Wed Jul 13, 2005 8:17 pm Post subject: |
Yea thats what I figured.I have the 8 spokes on there now because the car is just sitting,and I only get a little rub on the passenger side,but thats because the car was hit in the front so the left side fender is pushed out.I'm going to put the 8 spokes on the 67 I'm goin to sell and put the stockers on the 66.How hard are stock hubcaps to find?What about "smooth" aftermarket hubcaps?I'm goin with the flat black "sleeper" look(1914).I'll try to get a pic of my car soon. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Jul 13, 2005 8:22 pm Post subject: |
if it is stock 4 bolt wheels, the hubcaps are the same as a bug. Shouldnt be too hard to find in SoCal. People should have them in their junk box.
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
littlebuggie Samba Member
Joined: March 23, 2004 Posts: 698 Location: California
Posted: Wed Jul 13, 2005 9:28 pm Post subject: |
My 66 square is low as it can get.. I don't have any bump stops. Stock 135s _________________ Subi swaps welcome! |
Posted: Wed Jul 13, 2005 10:22 pm Post subject: |
Solow you got any pics?Right now I still need to cut the bump stop arms off of my car.As they're still hitting when I go through a dip(only did it once) |
73notch Samba Member
Posted: Wed Jul 13, 2005 11:54 pm Post subject: |
you might regret cutting those bump stops off. If you think about it, without those stops, and you hit a bump, the front beam will smash the pavement.
whats better, bottoming out on the bumpstop mounts, or getting a little more clearance only to smash the front beam into the pavement, and possibly tweak your entire front beam setup.....
best idea would be to grind it down, and hook a threaded urethane bumpstop there so you can adjust the stop point.
-Ryan _________________ SubyNotch.com is back up! |
Posted: Thu Jul 14, 2005 1:13 am Post subject: |
I dont think I understand what you mean by hook a bump-stop on there.It is 1 in the morning so that might have somethin to do with it.But the acutal bumpstop is already cut off,but the metal mount is still on there.I'll go take a look at some bumpstops to see If I can figure out what you mean.
Thanks,
Philip |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Thu Jul 14, 2005 5:37 pm Post subject: |
Russ Wolfe wrote: |
We use ours as Frisbees™
Yeee Haaw. _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Thu Jul 14, 2005 6:39 pm Post subject: |
lol I bet.I wasn't sure if they were the same or not.I figured they'd be different and harder to just because its goin on a type 3.Alright so it looks like 135's are the answer for the front,I've got 2 rims with good 165's and 2 rims with 195's,and the 195's do look very "bulgy". |
Posted: Thu Jul 14, 2005 6:45 pm Post subject: |
Notched wrote: |
Yeee Haaw. |
Or to water the Dog.
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Fri Jul 15, 2005 5:00 am Post subject: Re: Stock rims on Lowered Car |
66fasty wrote: |
Thanks,
Philip |
I have stock steelies on my square -- the front is lowered 2 clicks and I run 195/60's all the way around... no rubbing at all... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Fri Jul 15, 2005 9:25 am Post subject: |
No Bump Stops,135s
60DoubleTurd Type 3 Contributor
Posted: Fri Jul 15, 2005 9:26 am Post subject: |
175/55/15s will get you all the way to the floor and still give you decent tunring with the stock wheels because of the offset. _________________ Frank
66 L87 Variant Pigalle
SBS #17 |
Posted: Fri Jul 15, 2005 12:17 pm Post subject: |
Do stock 5 lug rims have the same offset as stock 4 lugs though?I would really like to have a significant amount of tread on the ground,and a 175 is probably quite a bit more than a 135.62type3square,what size tire are you running on the rear?Any full pics of the car?
Thanks,
Philip |
hoss Samba Member
Joined: May 01, 2003 Posts: 788 Location: San Jose, CA
Posted: Fri Jul 15, 2005 12:48 pm Post subject: |
Here is a full picture of franks car before our attempted trip to bug-o-rama... Don't remember exactly what size tire he has in the rear... But they fit perfect on the stock 4.5" wide rim.
_________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
Posted: Fri Jul 15, 2005 1:24 pm Post subject: |
Thanks for the pic!My cars not nearly as low as his is,its closer to SoLow-Square's.I'd like to have it as low as Franks though lol.I dont know how well it would do out here though(Dips)Looks REALLY good though! |
