biggraham Samba Member
Posted: Tue Jul 19, 2005 3:19 pm Post subject: Type 3 discs with different bolt patterns.... |
Hi
I'm in the process of adding a type 3 disc equipped Bay Window beam in my Splitty, does anyone sell just the discs alone with different patterns, I'd prefer not to use adapters...
Thanks
Graham _________________ 67 S0-42 Pop-Top Walkthru |
hoss Samba Member
Joined: May 01, 2003 Posts: 788 Location: San Jose, CA
Posted: Tue Jul 19, 2005 3:54 pm Post subject: |
i do beleive airkewld just adverstised something like this. it's in the thread on type3 dropped spindles. _________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Tue Jul 19, 2005 3:58 pm Post subject: |
You steal our parts, then ask for help? Sheesh.
Will the discs fit on the spindles with the stock bearings? I've never heard of this before. I'd be really surprised if this will work.
Oh, to answer your question, I don't think there are blank Type 3 disks available. Mr. Airkewld seems to be making progress on some after market disks for the front of a Type 3, and states that any bolt pattern is available (somewhere he said that, not in the selection):
http://airkewld.com/parts/products.php?id=27&PHPSESSID=f54329ce8c0409a4bd861b0360f7dc85
You'll have to scroll down for the rotor only package - kinda steep at $220/pair (says ea. but I think that's for a pair). _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
R.Rabbit Samba Member
Posted: Tue Jul 19, 2005 9:29 pm Post subject: |
I converted the front of my 65 from drum to disc up front with 69 T3 spindles and Ghia rotors drilled to Porsche 5x130 pattern. I used new races, bearings and tierod ends. No problems, in fact pretty easy. I got the spindles from Martin @ the DDB and the rotors from SoCalAutoParts in Long Beach, Ca.
If you've got a beam from a 66-71 (early) then all you need is the rotors, races and bearings. Note: Mid-71 to 73 is a differnent size spindle. _________________ Opportunity may knock only once, but temptation eff' leans on the doorbell!
SBS #5
'54 RHD Swedish 3-fold
'60 L345 Doppelkabine |
Posted: Wed Jul 20, 2005 12:41 am Post subject: |
Stealing is such a strong word....
The beam and dropped spindles are from a 68 bus.
$440 makes me think of Porsche... _________________ 67 S0-42 Pop-Top Walkthru |
PIMPPRIDE Samba Member
Joined: November 19, 2003 Posts: 879 Location: Carson California
GearheadJim Samba Member
Joined: April 10, 2003 Posts: 180 Location: Columbus Ohio
Posted: Wed Jul 20, 2005 2:04 pm Post subject: |
Hey Airkewld Pete, I find it hard to believe the rotors will NEVER wear out. Care to elaborate: what's the material, lifetime warrenty, how long has the manufacturer been in business, ... _________________ Drive 'em!
65 Notchback build: https://www.thesamba.com/vw/forum/viewtopic.php?t=773405 |
Posted: Wed Jul 20, 2005 4:02 pm Post subject: |
I can see the rotor is the strong point, but is braking really improved? it looks like it uses a stock VW caliper, I can see the benefit of wanting to change lug patterns often, how much does it cost when you want to change lug patterns from one set to another?
Anthony / ISP WEST |
Posted: Wed Jul 20, 2005 5:06 pm Post subject: |
Airkewld wrote: |
They are $220 a piece. |
Oops. Sorry I miss-quoted the price...
They look really nice, BTW! May be a tough sell for us cheap Type 3 owners... _________________ Phillip Bradfield
Posted: Wed Jul 20, 2005 6:37 pm Post subject: |
PIMPPRIDE wrote: |
Well i dont know how improved it would be over the stock Ghia set up but its the advantages that make this kit special. If you have drum brakes, this kit gives you a big advantage. If you want an improved "stopping so that you get flung out the windsheild", porsche is probably the way to go, but who wants to spend 100 bucks on brake pads. I guess i am looking at the problem everybody has when it comes to brake upgrades. Patterns, track width, replacement parts, ie bearing brake pads etc.. and rolling weight when it comes to racing. Whats even better, you still dont have to buy another rotor ever again and you can have wide five with out added track width. Different bolt patterns run about $60 per side, wide 5 slightly higher. _________________ TheSamba members-only discount - Samba24
Win a FREE Chassis Rebuild - https://airkewld.co/WinAChassis
Learn from a PRO on Patreon - https://www.patreon.com/Airkewld
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba |
FASTBACKDON The other insensitive jerk like Neil
Joined: October 08, 2004 Posts: 3592 Location: TORRANCE CALIF
Posted: Wed Jul 20, 2005 7:01 pm Post subject: |
pimp i bought the same rotoers for the front of my fastback same rotors at bill and steves 50 bucks each drilled for alloys |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Jul 20, 2005 8:39 pm Post subject: |
Not all of us are cheap. I'm considering a pair down the road drilled for 5 lug on my 34 Ghia. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Wed Jul 20, 2005 11:00 pm Post subject: |
Airkewld wrote: |
porsche is probably the way to go, but who wants to spend 100 bucks on brake pads. |
Come now, Porsche pads aren't that expensive. Guy down the street from me just replaced the pads on his '88 944 for under $75 with good Raybestos that he got at Schucks (AKA Kragens). Not top-of-the-line racing stuff, but who really needs that grade of pad on a street-driven VW anyway? |
Posted: Thu Jul 21, 2005 9:38 am Post subject: |
FASTBACKDON wrote: |
$50 each wow thats a deal!
no matter who you buy parts for your car from ( Bill & Steve's, JC Whitney or Serrano's ) I can guarantee you did not get the same rotors with pressed in studs that I am selling for $50 each
Airkewld wrote: |
Well i dont know how improved it would be over the stock Ghia set up but its the advantages that make this kit special. If you have drum brakes, this kit gives you a big advantage. If you want an improved "stopping so that you get flung out the windsheild", porsche is probably the way to go, but who wants to spend 100 bucks on brake pads. I guess i am looking at the problem everybody has when it comes to brake upgrades. Patterns, track width, replacement parts, ie bearing brake pads etc.. and rolling weight when it comes to racing. Whats even better, you still dont have to buy another rotor ever again and you can have wide five with out added track width. Different bolt patterns run about $60 per side, wide 5 slightly higher. |
are your making 2 different center hubs? you know pre 1965 type 3's have different spindles right... I ask these questions not to knock on your product, but for information,
I actually drive a very potent street type 3 that I always look to improve, ( better brakes would be one of them )
your setup aesthetically looks good ( insert bling' bling' here ) and the ability to change wheels often is great and the ever lasting rotor too... but in my opinion it most likely is not going to perform any better then a stock system, if it was packaged with a 4 piston caliper and had a larger pad to rotor surface contact this would be an big improvement for cars with major horsepower and braking issues,
Posted: Thu Jul 21, 2005 12:05 pm Post subject: |
PIMPPRIDE wrote: |
but in my opinion it most likely is not going to perform any better then a stock system, if it was packaged with a 4 piston caliper and had a larger pad to rotor surface contact this would be an big improvement for cars with major horsepower and braking issues, |
Thank you for finding the point I was too drunk to make last night.
The rotor itself is a good start, but using that rotor with stock brake hydraulics (calipers, master cylinder) and stock pads just ain't going to make as much of an improvement in braking as bigger Porsche calipers and a bigger master cylinder can make. |
73notch Samba Member
Posted: Thu Jul 21, 2005 2:32 pm Post subject: |
you mean like this?
-Ryan _________________ SubyNotch.com is back up! |
