Mead Samba Member
Posted: Tue Jul 26, 2005 7:52 pm Post subject: Busted FI Fuel Pump |
The fuel pump on my 1970 FI squareback quit on me, it won't kick on at all. Im trying to find a replacement but am coming up short. The only ones ive been able to find so far are almost 400$ Ive checked ebay and the classifieds here, i was wondering if anyone knows where I can find one for significantly less than that. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Jul 26, 2005 7:59 pm Post subject: |
I am using a 1985 Ford Ranger pickup pump in my '71. Took a little re-engineering the mount, and rerouting some fuel lines, but it has lasted for 3 years, and only cost me $20 used.
BTW, are you sure it is the pump?? Have you tried hot wiring it??
When you turn the key on, do you here 2 relays click, about 2 seconds apart?? The pump should run between those 2 clicks.
If you don't here the clicks, then the FI relay is not coming in or the computer has no power. Check the wire coming off the battery to the FI power relay under the rear seat. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
wolfman's brother Samba Member
Posted: Tue Jul 26, 2005 8:00 pm Post subject: |
i've got a used working one laying around somewhere in the garage i'd be willing to part with once I dig it up. _________________ insanity takes it's toll,please have exact change ready.
my imaginary friends keep telling me I have a mental problem. |
Kevin S. Samba Member
Joined: May 23, 2005 Posts: 113 Location: Vancouver, Washington
Posted: Tue Jul 26, 2005 9:39 pm Post subject: |
Check woth the DDB. I took my 1971 Fi stuff to Martin. It all worked. I am not sure if they interchange. But I know that he has some Fi stuff at his shop. _________________ Do you feel lucky???? |
Mead Samba Member
Posted: Tue Jul 26, 2005 10:11 pm Post subject: |
yeah, we checked all the power stuff as i thought that might be the problem since I just replaced the voltage regulator but we've got power to and from everything the pump just isnt kicking on. It's the original so it's 35 years old and it spend 34 of those years in milwaukee so the pump looks like it's in pretty rough shape anyway. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue Jul 26, 2005 10:20 pm Post subject: |
Make sure that you also have a proper ground before you condemn the pump. Oftentimes this is overlooked. You need BOTH power AND ground to make things work. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Wed Jul 27, 2005 5:44 am Post subject: |
keep an eye on the classifieds for people selling fuel pumps - also eBay; I bought a brand new one for $100.00 from the classifieds... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
