aussie01 Samba Member
Joined: July 16, 2003 Posts: 300 Location: Gold Coast, Australia
Posted: Sat Jul 30, 2005 1:19 pm Post subject: removal of fan housing |
how do I removal the fan housing? It would seem to be held together where the engine hanger and the breather are and i can't see how to seperate them. Sure to be a simple procedure, I'm just not seeing it! |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Jul 30, 2005 1:27 pm Post subject: |
There are 2 dowel pins in the corners, underneath. There are a couple places where you can get a screw driver in to pry. Just make sure you do have all the bolts out. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
FASTBACKDON The other insensitive jerk like Neil
Joined: October 08, 2004 Posts: 3592 Location: TORRANCE CALIF
Posted: Sat Jul 30, 2005 3:22 pm Post subject: |
yea what russ said |
Posted: Sat Jul 30, 2005 4:23 pm Post subject: |
I've got it loose and it wants to seperate apart, but the 2 halves are being held together where the engine hanger/breather is. How do I seperate here? I've undone the bolts where the breather support connects to the case, it's all loose there as well. |
Posted: Sat Jul 30, 2005 4:25 pm Post subject: |
Right under that hanger, there is a bolt, and a dowel pin. the dowel pin is for alignment but will hold it together unless you pry a little. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sat Jul 30, 2005 4:32 pm Post subject: |
ahhhh, found it, there's a bolt hidden inside the hanger!!!! It helps when I turn all my garage lights on!!!! |
Posted: Sat Jul 30, 2005 4:35 pm Post subject: |
now the fan???!!!! I saw a posting in search about using a harmonic balance tool to pull this. Is this just a standard item to be found at NAPA? are they inexpensive??? |
Posted: Sat Jul 30, 2005 4:46 pm Post subject: |
yea a puller will work just make sure you line up the bolts to the holes if not you wont like the out come pluse use a spray lube wd-40 or breakfree anything it should slide right off |
Posted: Sat Jul 30, 2005 5:01 pm Post subject: |
Just get a cheapy puller. If you have a Harbor Freight in your area, they sell them for like $6.95.
Woops, they don't have the 6.95 one listed anymore, but they have a $10.95 complete set.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=37824
Just DON"T pry on the fan. You will bend it,
While it is off, check the center hub for looseness. The fan is mounted in rubber. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sat Jul 30, 2005 5:20 pm Post subject: |
wow, a bit of wd40 and it pulled right off, no tool needed!! |
Posted: Sat Jul 30, 2005 5:44 pm Post subject: |
aussie01 wrote: |
And who says WD-40 isn't "God in a Can". _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sat Jul 30, 2005 6:00 pm Post subject: |
Russ Wolfe wrote: |
aussie01 wrote: |
And who says WD-40 isn't "God in a Can". |
that may be true, but it is not a lubricant.... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
