inthecurl Samba Member
Posted: Sat Aug 06, 2005 12:38 pm Post subject: T3 trans gears help??? |
I am looking for the R & P gears and final 4th gear ratio in a 64' Notchback 1500S... I have looked at the previous topics to no avail. Any help would be greatly appreciated!! |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Aug 06, 2005 12:59 pm Post subject: |
Do you want just the ratios's, or do you need the actual gears??
Here are the ratios.
http://classicvw.org/gallery/my_misc/Ratios?full=1
Same as a T-1. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sat Aug 06, 2005 3:32 pm Post subject: |
Wondered why yours showed different, until I looked at an older Without Guesswork.
The one I showed the first time is a '71-'72.
This one is 1960 thru 1970.
http://classicvw.org/gallery/my_misc/ratios?full=1
4th gear changed with the '68 model year. And all t-3's if I read it right had 4.125 final drives where the early T-1's had a lower ratio. 4.375. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sat Aug 06, 2005 5:02 pm Post subject: |
Thanks guys for the help. I didn't tell the whole story, and I'm in the wrong forum, but it's for my 62 bus. I have a full flowed 1915 with all the bells and whistles and am putting in a straight axle kit and my donor was a 64 T3 trans... ( Don't worry, the Notch was totally destroyed ) I just wanted to find the gears to see if they would work well. Tires are 195-60-15...
Thanks for the info guys. |
