QUADRADO Samba Member
Joined: August 10, 2005 Posts: 135 Location: 91sickness
Posted: Wed Aug 17, 2005 12:00 pm Post subject: Bolt location help! |
Hey guys does anybody hae a diagram or the locations of the bolts that hold the shell on to the pan on a 68 fastback? how many are there?
I need to get this shell off so I can send the pan out for sandblasting and sealing. |
60DoubleTurd Type 3 Contributor
Posted: Wed Aug 17, 2005 2:44 pm Post subject: |
Dont have a diagram but there are about 7 on each side under the rockers, 4 big ones up front by the pedal assembly and the tunnel that I think are 19s, and about 4 big 17 or 19s under the back seat and 4 regular ones under the back seat as well. Just take off all you find and then '''''''shake''''''', where ever its tight look for one you missed!! _________________ Frank
66 L87 Variant Pigalle
SBS #17 |
FASTBACKDON The other insensitive jerk like Neil
Joined: October 08, 2004 Posts: 3592 Location: TORRANCE CALIF
Posted: Wed Aug 17, 2005 2:52 pm Post subject: |
I agree with 62 the ones under the rear seat seem to hide remember the body will be stuck to the rubber gasket lift one corner at a time pull off all the sheet metal you can type3's are fricken heavy compared to a bug good luck keep us posted |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Aug 17, 2005 4:26 pm Post subject: |
Here are the ones on a bug.
http://classicvw.org/gallery/my_misc/body2chassisboltlocations
T-3's are in about the same locations. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Wed Aug 17, 2005 8:05 pm Post subject: |
Don't forget to unhook the brake fluid res lines, and the steering column. The lines are the easiest to forget, but there are also 2 more bolts on the top of the front axle (right above the beam clamps), and 2 more hidden in the rear load floor (above the rear shocks). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Aug 17, 2005 11:58 pm Post subject: |
Guys thank you so very much for the helpful information.
I will post pics of the pan once its blasted and epoxy sealed. |
